- Jul 14, 2004
- westminster, CO
So I just took apart my rig recently and noticed that I had some nickel corrosion going on in my gpu water block after cleaning my system. I read about huge issue with corrosion and the nickel plating for a lot of folks that was caused by silver, phosphate biocides, and distilled water being used together. Odd thing is my cpu block looks perfectly fine and it's nickel. I've only been running distilled + killcoil.
I emailed their support with a picture, quick caption, and when I bought the product. I mentioned that I was a few months out of their 2 year window for warranty but its a defective product and it should be replaced. I didn't know about any of it as I bought the block before these reports surfaced. They said send in the necessary info to RMA and they'll take a look. 5 minutes after I have everything uploaded, they deny it saying I'm out of the 2 year window lol. What was the point of that? I already stated when I bought it so why make me go through the hassle of taking apart my block and taking photos once again only to be denied RMA when I gave that information upfront.
*Edit* I should have been more clear. This is less of a warranty issue and more of EK not honoring a recall they did on pretty much the entire line of nickel blocks at the time. This is also an ISSUE that is well documented and EK even admits so my block being faulty is NOT DEBATABLE. They used a cheap process called electrolytic plating because it can be up to 4 times less than electroless plating. They have since switched to electroless and that is what I wanted to RMA for.
Long story short, EK sucks don't buy their stuff. After reading about everyone else and their experience, I'd prefer to stick to brands that you know take care of business when their product fails or not use cheap lesser quality processes without any testing.
