Hey there, I have a thread I posted before this but it was in the wrong forum, but we all came to the conclusion that my mb may be bad. I thought I would bring it the the MB section itself, because obviously you guys are more informed on MB's. A lot of this is copy and paste from the other forums, so here goes and I appreciate all the help.
Ok guys.. I got my build all together and done.. but of course there's always gotta be problems (but not smoking yet)....
I start my comp up, mobo shows 19, then switches to code 15.... turns itself off... reboots up... with code 10 on.... will stay running forever (with all fans on, and everything in the computer running) on code 10... All this time, never putting out any signal to my monitor. I haven't even gotten to load windows on it or nothing. It won't POST.
I looked up my ram and it isn't the 'supported memory' ? Like 2 letter off -_-... could that be it? If so i'm going to be so pissed off.
So annoying to spend all this money on it, and have it work but have errors and nothing able to do about it...
Looked in book and the code 15 and 19 are just north/south bridge initialization. Code 10 is PEI Core initialization.. Sigh. PLEASE HELP!
I have reset CMOS.
I bought a sandy bridge cpu (a celeron G530) incase the bios was out dated, still didn't work (I have the 3770k ivy bridge that's why I bought the sandy)
Reseated everything, including the processor(s)
No pins broken/bent.
PSU is fine.
I have reset the MB also.
I tried diff ram from my other comp and it drew a few beeps from the MB, and a code 55.
I pulled everything out and did a test on a cardboard box, so it ruled out the MB shorting on the case.
I have incompatible ram atm, (only like 2 numbers off on the model number) so I have some compatible ram on its way. Could this be the problem causing this strange sequence of codes? Incompatible ram?
Here are some links that kinda relate to what is happening to me. Same motherboard also.
http://forums.anandtech.com/showthread.php?t=2251305
http://www.tomshardware.com/forum/317517-30-asrock-extreme4-debug
I have reset CMOS.
PSU is fine.
