EspElement said:
use the 3rd or 4th sata spot for ur raptor.. and u will beable to get over ur 240 wall :-D
i had that board.. and SAME problem
Hey there, I appreciate the helpful sentiment but I've known about this for a while. I only use Sata 3 or 4 spot for the Raptor.
The problem is a lot more complicated than that.
1) The graphics card just won't overclock well above 435/1.14 (stock is 425/1.10)... even though I bought the Zlaman cooler for it a long with the Modstream 520 just to make sure it gets enough power. It stalls in the middle of games (sometimse crashes) and then continue (with poorer frame rates). The only solution I've found is by increasing the aperture size in the BIOS to it at 512MB but still can't overclock any higher.
2) The memory I've switched to 2T and the Gold edition OCZ just won't take anything more than 2.9 V. I can keep it at a marginal overclock +10 Mhz (260X2 DDR) but it wil still crash at 3.0V no matter what. So Iv'e never been able to get it higher 278 at 2.9V.. and honestly I'd like to take it to the max it can go stable/healthy.
3) The new stick of OCZ 3500 Platinum Edition I just bought 2.5-4-3-7 has two issues:
a) when I combine it with the other two sticks of OCZ 4000 (maximum of 768 Mb on this board -256X3) it won't clock higher togehter than 236..
b) when I put one stick of platinum and one stick of godl edition in (512 MB) only, it will go up to 260 just fine (haven't tried going any higher).
So I have no idea why all three sticks won't go higher than 236 in combination. I glanced over the manual and it said that if all three slots are full of double rank memory then it will be soemthing DDR200 and DDR333 at 1T and 2T respectively whereby if only two slots are full it will be DDR333 and DDR400 respectively. I'm not to sure I know what they are talking about in here, but perhaps that's why all three sticks won't overclock very high when combined? Does it have anything to do with this? And if so what can be done about it?
3) And last, I can give the processor 1.6 V (over the 1.55 V) and it will overclock to 2.6 Ghz just fine. Even if I give it a **** load more of voltage (max 1.78 volts 1.55 + 110%) it won't go an ounce faster. I'm VERY VERY dissapointed with this processor as this is only a 200 Mhz overclock max from the stock of 2.4 Ghz. Whereby my old 3000+ went from 2.0 Ghz to 2.50 easy (500Mhz overclock). Is there anything I can do to increase the overclock? I bought the Zalman 7700 Cu just for this.
Would appreciate the suggestions, makign this into a forum topic on DFI's board as well.
