what are you using ? get better performance here with lev1DRAM Drive Strength**= Level 1-4.
I would only suggest using Level 1 or 2, if you have CPC enabled.(although every sysem will react differently, and it is best to try them all) With CPC, anything above level 1 gave me extreme instablility, some reported that level 2 or 3 work good with CPC enabled, although this didnt work for me. Some otheres have had success w/ using level 2-4 if CPC is disabled.
Grov said:Where is Jess? i ain't seen him for ages.
Clevor said:This board looks way slower than the Abit NF8 though. I am doing more comparison benching and will post my results on the Abit forum (Nvidia S754 boards). Doesn't look too good considering BH-5 is in the board now . Plus I'm running this DTR at 2600 mhz.
BSViper said:Are you complitely sure?
It's very strange, cause memory controller integrate in CPU, an other stuff on that two boards looks like identical..
Any way, my guess - too late for Abit with his NF8...
Now, socket 939 boards much more interesting for buyers...
THunDA said:Clevor.. What are your other timings besides the normal 2-2-2 ones ?
Clevor said:Anybody using the beta BIOS dated 1-28-05? It is supposed to improve bandwidth, but don't know if it has VDIMM to 4.0. I kinda doubt it as it is from DFI.
THunDA said:Try Jess's settings.. then you have to use his guide to tweak down what your ram can handle..
1\28 has Bank Interleaving and if your ram likes it then it will boost bandwidth.. unfortunatly my tccd doesnt like it but my bh5 does..
Here is TicTac's forum and a download of the 1\28 with 4v vdimm.. that im using..
edit..
BTW.. this thread is long but very educational.. worth a read.. I did..
