- Dec 6, 2010
- Thread Starter
- #141
Both PC's log shows no work available...
I'm getting work, restart F@H or reboot PC and see if that works.
*********************** Log Started 2021-06-24T23:51:07Z ***********************
23:51:07:Trying to access database...
23:51:07:Successfully acquired database lock
23:51:07:Read GPUs.txt
23:51:07:Enabled folding slot 01: READY gpu:0:GA102 [GeForce RTX 3080]
23:51:07:****************************** FAHClient ******************************
23:51:07: Version: 7.6.13
23:51:07: Author: Joseph Coffland <[email protected]>
23:51:07: Copyright: 2020 foldingathome.org
23:51:07: Homepage: [URL]https://foldingathome.org/[/URL]
23:51:07: Date: Apr 27 2020
23:51:07: Time: 21:21:01
23:51:07: Revision: 5a652817f46116b6e135503af97f18e094414e3b
23:51:07: Branch: master
23:51:07: Compiler: Visual C++ 2008
23:51:07: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:51:07: Platform: win32 10
23:51:07: Bits: 32
23:51:07: Mode: Release
23:51:07: Args: --open-web-control
23:51:07: Config: C:\Users\chex3\AppData\Roaming\FAHClient\config.xml
23:51:07:******************************** CBang ********************************
23:51:07: Date: Apr 24 2020
23:51:07: Time: 17:07:55
23:51:07: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
23:51:07: Bits: 32
23:51:07:******************************* System ********************************
23:51:07: CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
23:51:07: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:51:07: CPUs: 6
23:51:07: Memory: 31.93GiB
23:51:07: Free Memory: 27.75GiB
23:51:07: Threads: WINDOWS_THREADS
23:51:07: OS Version: 6.2
23:51:07: Has Battery: false
23:51:07: On Battery: false
23:51:07: UTC Offset: -4
23:51:07: PID: 9832
23:51:07: CWD: C:\Users\chex3\AppData\Roaming\FAHClient
23:51:07: Win32 Service: false
23:51:07: OS: Windows 10 Enterprise
23:51:07: OS Arch: AMD64
23:51:07: GPUs: 1
23:51:07: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]
23:51:07: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.2
23:51:07:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:461.40
23:51:07:******************************* libFAH ********************************
23:51:07: Date: Apr 15 2020
23:51:07: Time: 14:53:14
23:51:07: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:51:07: Bits: 32
23:51:07:***********************************************************************
23:51:07:<config>
23:51:07: <!-- Folding Slot Configuration -->
23:51:07: <client-type v='advanced'/>
23:51:07:
23:51:07: <!-- Network -->
23:51:07: <proxy v=':8080'/>
23:51:07:
23:51:07: <!-- User Information -->
23:51:07: <passkey v='*****'/>
23:51:07: <team v='32'/>
23:51:07: <user v='dfonda_Team32'/>
23:51:07:
23:51:07: <!-- Work Unit Control -->
23:51:07: <next-unit-percentage v='100'/>
23:51:07:
23:51:07: <!-- Folding Slots -->
23:51:07: <slot id='1' type='GPU'/>
23:51:07:</config>
23:51:07:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:51:08:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:51:08:WU00:FS01:Connecting to assign2.foldingathome.org:80
23:51:08:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:51:08:WU00:FS01:Connecting to assign3.foldingathome.org:80
23:51:08:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:51:08:WU00:FS01:Connecting to assign4.foldingathome.org:80
23:51:08:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:51:08:ERROR:WU00:FS01:Exception: Could not get an assignment
23:51:08:3:127.0.0.1:New Web session
23:51:09:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:51:09:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:51:09:WU00:FS01:Connecting to assign2.foldingathome.org:80
23:51:09:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:51:09:WU00:FS01:Connecting to assign3.foldingathome.org:80
23:51:09:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:51:09:WU00:FS01:Connecting to assign4.foldingathome.org:80
23:51:09:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:51:09:ERROR:WU00:FS01:Exception: Could not get an assignment
I think I know what is going on here, all of you that is not getting any WU's or having trouble getting them is using the flag Advanced for client type. I know HayesK is using beta flag for client type and I am too.
Try beta for 1 or 2 rounds of WU's to see
Ya working again for me, I just did the default install of the folder, presume it sets adv flags by default.
Work servers down, I'm not getting any new work.
Appears to be some change in assignment server code which does not fall back to non-beta wu when no beta wu available. need to remove the client-type = beta. Currently getting wu assignments with
client-type = <blank>
Thinking that the assignment server client-type fallback scheme is broken. Used to fall back from client-type beta => advanced => normal when no wu of request were available. With client-type = advanced, my 970 (nv species 5) caught p13455 but the 980Ti (NV species 6) had no assignment. Then I changed the 980Ti client-type to <blank>, next attempt recd p17806. The p13455 assignments are restricted to the "narrow" gpu, nvidia species <= 5. Apparently there are no other projects available with the beta or advanced setting, thus the need to remove the client-type setting value.
I recently received notice from my hosting company they are moving to a new datacenter in-town. A professional moving team that specializes in this sort of thing will be handling the whole process.
The maintenance window for this move is between 9:00 pm CDT Friday July 16th till 6:00 am CDT Saturday July 17th.
I'll probably shutdown the server an hour or two before the scheduled move time just to be safe.
Same network(s), same IPs, same everything. Nothing should change.
Doing some extra backups beyond my normal schedule, just to be safe.
