- Jul 29, 2011
- Buenos Aires, Argentina
Yeah, the price is not bad, and I want to be able to spin it slower whilst keeping decent CFM too, hence the 140mm fan as opposed to 120mm.
I guess it would be okay to use a high pressure fan at the intake where hard drive cages are located then?
depends on your HD-cage, I have seen pretty tight boxes with small gaps, for those, higher Static pressure preferred yes. But for general HD cages, the gaps are wide enough for you to just focus on a high CFM/low noise fan without worrying too much.
High static pressure always a huge BONUS to have as chassis fan. But the word 'high pressure' is actually relative. If you Chassis is net positive, the pressure inside is high, and adding a low pressure fan, actually doesn't do too much more. If your chassis is net negative, than even a low pressure fan can blow in good force CFM...
but since net positive never hurts.
therefore net high pressure never hurts much either.
just be sure you don't sacrifice too much CFM or Noise there
In General, I prefer 120mm fans anytime of the day too.
basically everything at 140.. I can kinda find a 120mm fan that does the same if not better... with the exception of Prolimatech's Aluminum Vortex.
My case is corsair 650d I have replaced the front intake with a 200mm Bitfenix Spectre Pro. The CFM is 148. I have a Corsair h100 and I want to replace the included stock fans as well as the rear 120mm stock exhaust fan. While maintaining positive air pressure in the case. Do you have any fan suggestions?
for the H100, the radiator is just 240 long, so for good cooling solution, the Gentle-Typhoon AP-15 might not offer enough CFM. You can consider the Scythe SlipStream 1900, and put them in Push/pull config, that fan capable of pushing a LARGE amount of air, but it NEEDS push/pull to overcome its low static pressure weakness. In Push/Pull though, they do GREAT.
noise wise it is ok. Doubt you will mind.
If you want more quiet fans of similar calibur:
Reeven 2k RPM.
If you want a bit more performance and don't mind noise
Cooljag 2400 RPM.
all of these will work for you.
and as always.. if you are not really looking to MASSIVELY overclock. a set of Enermax Duo (the 1700 RPM at 85 CFM) or the CoolerMaster 1900 RPM at 90CFM fans will also do quite well. But all of these fans will likely require a push/pull config to get enough performance for you.
and regardless, ANY of the above, will be an upgrade from the corsair stock fans.
How much of a efficiency loss will a fan with static pressure of 3 mm/h20 or of 2 mm/h20 have? is there a table or chart I can reference?
Thank you for answering. My question now, I'm a bit confussed after reading your initial post because you talked about having positive pressire. My intake is 148 CFM, wouldn't adding those high CFM fans create negative pressure in the case.
