altec said:I am gonna let it dry for like 24hrs. Will there be any negative results if I take a blow-dryer to it for small intervals of time?
PerpetualBliss said:the pump needs to match the set-up very well or efficiency will drop like a rock.
It isn't the relative velocity adding pressure. It's the restriction that adds back pressure. Remember with the WW the actual flow rate is decreased. Unlike adding a bigger pump where the flow rate itself creates the added pressure.
don't go overboard with the pump Cathar considers the WW a mid-flow block and warns against using anything larger than a Eheim 1250 and states even that is operating inefficiantly. Dumping too much heat back into the system.
I'd think a Eheim 1048, Hydor L20 or Danner 250 would be about perfect.
If the computer wasnt on when the hose came detached you will probably be O.K. BUt man that would have scared the !*$#@! out of me. GOOD LUCK.
