- Apr 24, 2007
Well, everything arrived from Danger Den and Petra's on Friday and I took Saturday and got it all taken apart and put together again. Relatively problem free for a first WC case mod. Here's a list of parts and my work log with pictures.
DD MC-TDX CPU block
680i NorthBridge block
Tygon 1/2" ID tubing
DD Fillport Reservoir with Fillport
Black Ice 2 Radiator
D5 variable Pump
4 YL Med. Fans
Scythe KamaMeter Fan controller/temp monitor
T-Line Res -> Pump -> Rad -> CPU -> NB -> Pump
Rad with 4 Yate Mediums. Leads prepared for install into the drive bay of my 900.
Case gutted and rad fitted. Lot's of room in here. Echo echo....
My 680i with the chipset cooler removed. Notice the Scythe 4fan controller in the background. It's not bad, and allowed me to get rid of alot of cable mess. That alone was worth the $50.00
Hole drilled through plastic and metal for fill port.
Fillport installed. These things look sooo cool.
Blocks installed on CPU and NB. And that POS southbridge fan. It's by far the loudest part of the system. I'll go passive as soon as I can find a good HS.
Tubes cut and fit around components. Reservoir installed onto fill port.
Components removed for leak test. I'm too lazy to leak test outside the case.
All done, working like a charm. I'll let the paste burn in, then report on temperatures.
FYI: In the two pictures above, the intake and output CPU tubes are switched. A buddy of mine got the exact same setup at the same time and were surprised at the lack of documentation with the CPU block, and on the website. Particularly which were the intake and the output barbs. It's not as intuitive as you would think, and arguments could be made for using either of the barbs for intake or output. He put his on, what we now know is the right way, and I put my tubes on opposite. I have since switched them to the correct configuration and can report that there was only 2-3 deg lower temperatures recorded.
DD MC-TDX CPU block
D5 variable Pump
4 YL Med. Fans
