- Feb 10, 2008
- Quakertown Pa.
LOL i have no clue man i just made that up, you did a great job with your cable management you actually forced me to redo my case because it was a jungle in there...and i thought i would get it ready for my WC setup
and to be honest this case isnt bad if your 1. Handy 2. Motivated 3. Educated to play around with it....educated as in you read around on what others did
A small increase isn't bad, but your putting more stress on your mosfets, I think.
I pencil modded and only got an increase of .01v, mostly it stays stable. But I went ahead and bought a couple packs of the Enzontech Mosfet HS's and stuck them every one I could find.
Now i'm just going off of what I think is solid advice from someone else but, vDroop is there on some boards as a safeguard and pencil modding creates more heat and stress. Thus more cooling is needed. Even if i'm wrong, it's not a bad idea anyway.
Great job on that loop. The only thing differently I would of done is use a res instead of a fill port, eliminating that T-line. And maybe putting the Rad outside of the case. I really want to see someone use those rubber gromets on the back of the case. I still have my 900, the top grill and fan got busted up though. It's begging me to do another build.
