@ShrimpBrime - If you will re-read the OP, you may understand why I ignore suggestions involving different hardware. I do not have other hardware and this machine does not properly belong to me so I won't buy components to have installed. I don't have the experience to go far beyond plugging in memory myself, it's not my machine so I won't pay for new components, pay to have them installed, then ship the machine to it's rightful owner.
That said, I value your input as data that I may find useful should I ever approach the task of building my own machine.
Steve
It's quite understandable. However I gave advice to stabilize the machine before you had to do all that bios flashing which may or may not have been an issue in the first place.
So to help save you some time and aggravation, I was hoping to see some P-states and get you a stable running machine. Only because I am familiar with your motherboard and processor configuration. I should state Very familiar.
It ran at what looks like 43C cpu. Killed the job, shutdown, reinstalled all 32GB of memory and rebooted.
That is where I am now. I am somewhat concerned that the temperatures as I have them displayed may be for the wrong devices
A few screen shots says more than a thousand words. Personally I would imagine that 43c CPU under a full load would be a very low number considering the cooler in use. But then your software may not FULLY load the cpu cache like Prime95 or Intel Burn Test AVX edition. I do know from experience that Cpu gets too hot, it simply will not post. (heat soaked water loop)
Also, we touched on having a good power supply. If it can't handle the load, it may shut off. Again, this is just a possibility, we just want to be sure you have a good long lasting experience with your half good and half questionable hardware. BTW 15 minutes is a short test. Most here recommend 2 hours....
Part of asking questions may bring you a lot of answers, even if those answers are not exactly what you are looking for.
So after reading the entire thread multiple times, I am surprised any good advice would be ignored.
The FX-9590 is not for the average every day user. You are not the first nor the last to come here and all the other forums with the EXACT SAME problem every one else runs into (mainly non overclockers). Just because it's the fastest FX chip, does not mean it can be blindly handled.
