You're going about troubleshooting this problem all wrong. Do you have more than one AMD FX machine? I bought a computer with an Asus Sabertooth 990FX r2.0 about 5 months ago. I've had nothing but trouble, this is my first Asus motherboard, after hearing so much about them not sure I'd buy another. The problem IS the motherboard. There are thousands of posts on the internet about this combo freezing, with lots of solutions. Mine freezes and I have a very basic system running stock 9590 speeds. I've followed many forums and tried the simplest things and it still freezes aperiodically.
The best and easiest way to troubleshoot is to set your BIOS to defaults, and run it first. Make sure your memory is configured properly. IF it still freezes one guy suggested turning off turbo core, which I did, still froze. Then I tried messing with lots of voltage settings according to many posts. Still froze. I also ran my memory at a lower setting, still froze. Thing is I originally had the same 9590 chig in an Asrock Extreme 9 motherboard and ti worked fine. I bought a new system with the ASus and an 8350 with better graphics, more memory, bigger power supply. Don't believe everyone when they say you need a huge power supply, you can find lots of info that contradicts that especially if you don't overclock. It depends heavily on your graphics cards and memory. I have 16 gb, two 8 gigs sticks, in each system. I finally swapped CPUs and put the 9590 in the Ascrock system, and put the 8350 in the Asus system. Also, I have liquid coolers in both systems, nothing fancy, both are two fan small radiator systems but neither system every gets real hot. Both systems have Radeon R9 2X0, one 280 one has 270, graphics cards, but different models/manufacturers. One system, the good one with Asus board, has 1200 watt Antec PSU. The other has a 750 watt 80 bronze certified PS by thermaltake, I think? The Asrock (750w) system has two SSDs, the other 1 SSD, 1 HDD. So with basic bios default settings the ASRock with 9590 is always stable, no problem. The Asus is stable with the 8350, but NOT the 9590 no matter what I've tried.
I know others online who've also confirmed their Asus MB works fine with other FX CPUs. I've seen some get stable eventually with lots of tweaking of Voltages and/or turning off turbo core and/or adding cooling, etc. I can tell you that there are many that can't ever get the Asus / 9590 combo to work. It IS the motherboard, maybe it is just some MBs? In my experience, almost everyone who's put the 9590 into a different motherboard has had success.
If you have an extra computer, or extra parts, easiest thing to do is use known low performance MB settings and then start swapping parts until freezing goes away. However, from what I've seen it is the MB if you know everthing else is good. As a matter of fact I'm using my ASRock / 9590 computer right now, WITH the 750 W psu. No problems. I should note that my Asus system would freeze completely randomly, even when using very little load and low temps. It could also run high load / high temps and freeze randomly. Also, I have 4 AMD FX desktop systems, and 3 more desktops in our household. (I have 3 kids plus 2 media PCs). All our homebuilt and all very stable. The other AMD FX systems are solid, we leave them all on 24/7, usually in sleep mode when not using except for one which is the backup server. I typically don't overclock but I do some, but very conservatively and don't have problems. All but one of my FX systems are liquid cooled, as were two that I sold. One of my media PCs has a 6350 and it does run a little hot with no liquid cooling, but it is a really small case with only 3 fans but still runs solid. YMMV
