- Jan 22, 2011
- Berlin, Germany
Hello,
my rig freezes during gaming after some time. Sometimes 5 minutes, sometimes one hour. There are no artifacts or the like.
I ran memtest for 7 hours - no errors. My gpus are completely new - dual palit gtx 580s and are running at stock. They max out at 83 degrees. For the purpose of testing whether my 24 hours Prime 95 stable CPU OC caused the problems I reset bios cpu settings, but that made no difference. My PSU is a Corsair HX1000, so my components should be getting enough power.
If it isn't CPU, GPU or RAM, then what else could it be? The mobo? Can I test that?
Cheers,
Mark
Cheers,
Mark
