- Dec 19, 2005
- New York
JC,
It actually gets colder than -73*C. It actually produces an Error on the LCD... hahah
Gautam said:You guys still wanna talk risk/rewards?
man you guys are f***in insane!! ahhaGautam said:You guys still wanna talk risk/rewards?
Yes, it certainly is. Moisture that is...if your H2O is in the solid state, you're all right. The key is making sure everything stays well cold enough so that the frost doesn't turn to water. Usually you only get a matter of minutes of uptime before this starts to happen.foreverFLASH]First off, I can't understand how you can use these cooling systems that produce the condensation/frost in conjunction with electronic hardware. I always thought moisture of any kind is like absolutely forbidden to be around anything electrical. I guess I was mistaken...
