I going to buy new case and coolers for motherboard. If i change motherboard i will have to buy another windows license and that is too much.
Says who?
You don't need a new license if you change to another MB.
You need a new if you do NOT decommission the "old" one..iow you can not use ONE license on TWO machines, but if the "old" no longer exists you can transfer the license to a new machine.
It IS possible that you can not register/validate online, but that you have to phone microsoft and tell them that your motherboard burned up; but afaik there is no need to buy a new license.
I know, i read license, but current mainboard is working and if i call to MS and tell them, that it burn up, i can not use it anymore. In any case, it is my work PC, a talk my boss about this.
Two sided tape will not melt from the heat? Or you not talk about office two sided tape?Two sided tape or cable ties will work
I have some experience. Instead of putting it in the center i prefer use silicone spatula to spread all cpu surface with thin layer of thermal paste. In my opinion it is more effective. Also, i check every time, that no thermal paste beyond cpu cover.1) How much experience do you have with applying thermal paste? Do you use a rice size grain in the center or spread a smooth thin layer on the cpu HS?
I personally don't like the rice grain in the center...with the massive HS's such as yours and mine, I've tested several times and the center is always bare and the thermal paste spread to the outside of the HS.
2) Motherboard fans? The motherboard is usually the coolest component inside your case. What temp is your motherboard showing? The hottest thing in my case on idle is my old 10k rpm WD raptor drive at 37celcius.
Gonester, I can tell you I am not very sensitive to heat due to cooking at home a lot. However, when I had the 8350 on my M5A99X Evo the Nb Heatsink was painful to touch with the tip of my finger. I could have held it there but it was really hot.I just touched my CHV VRMs and could hold my hand on them forever if I pleased to do so. FX-8350 at 4.6Ghz with 1.42Vcore and CPU-NB at 1.28V. I completely agree with the notion that more phases in the VRM circuit are less prone to heat. I have only tested water cooling since moving the FX 8 core processors in Aug of 2012 and just swapped a giant air cooler onto my cpu last night. At the moment I am not even using my 92mm fan pointed at my VRMs and yet they are not even hot to the touch. Maybe it is all the air now being pulled over the Mosfet sinks by the giant azz air cooler. Not sure how it will all turn out since I just made the switch last night. Only time will tell the full tale.
RGone...
silicone spatula is probably very thick?
best tool to use is a piece of an old credit card, you cut the portion you need and bend it in half. Make sure you clean it before using and after you wipe the excess, clean it again before you start spreading the thermal paste more.
Bending the card in half allows you to hold one half while you spread the paste with the other half...works quite nicely and the card is much stiffer than a spatula.
Johan45 said:Yepper same here the Sabertooth barely breaks a sweat at realistic clocks.
Vrm's on the CHV are barely warm to the touch, I actually just got done running prime 2 hours at my 24/7 OC but now with the Ram @ 1866 and it passed. I guess it was after all the BIOS?!?!
Overclocking, the 8350 on AIR I did a bit on the EVO up to 4.4 and noticed I needed more Cpu V with the EVO/Air. I'm thinking the added heat + 6+2 Vrm section is the culprit. With yours you think it's the added heat, I know when I was really putting my foot on the neck of mine doing the Cinebench contest in March I believe. I dropped my room temps to about 40f my water temp was 16c and I was definitely using less Cpu V to get there.
