You're correct it doesn't and thanks.I guess it doesn't post when posting from my
Now an issue I see is CPUTIN 77c is too hot for my liking. What most of us do to help cool that section is put a fan blowing on the VRM/NB heatsinks I personally have a 80 mm mounted on mine and also if your case allows it, put a fan on the panel behind the motherboard or you can use double sided tape and mount one directly on the back of the motherboard as johan has you should see around a 10c difference if you do this.
Well I actually will. Games like battlefield 4 are heavily multi-threaded. Skyrim will just benefit overall from the increased clock speed. More and more games are becoming multi-threaded, so them being "cpu-bound" is quite an accurate description.
This is after 22 minutes of prime95 blend. Zero errors or warnings. Also, Mandrake. I have a sig, but for some reason, I guess it doesn't post when posting from my phone.
Those two little 40mm fans are on the NB and not really doing much for the VRMS to the left of cpu as we are looking at your picture. Less than 9CFM or so is all those tiny fans will push and that just never seemed enough for me. I was using a 120mm pushing from the upper end of my mobo so it pushes under and drafts across the opening for the rear of my cpu socket and since it is 120mm it blows down at the VRMs and UNTIL I put an air cooler on top of my cpu instead of my water block, I had a 90mm fan blowign directly at the VRMs. And n0 the socket temps never rose in either configuration in use depending on the cpu cooler type. You need some air over the VRMs not overflow from two tiny 40mm fans
RGone...
Depends on what card it is. But yea, just the fact that the game CAN place any sort of load on all 8 threads shows the game being multithreaded. Play an older call of duty, or just about any game. You'll see only 2-MAX 4 threads doing anything.Trying to get more than 50% usage from my 8 Intel threads myself..... And I do only run one card so maybe that's why?
I guarantee I can get this fx-6300 that high, but I built my liquid loop around almost silent operation, so this fx-6300 @ 5 ghz begins to overpower my cooling solution. And I'm not about to upgrade $200 worth of fans for the sole purpose of squeezing a few more clocks.And ouch....thought I read this FX-6300 was doing 5.2ghz......
WAIT edit? My apologies, it was Rgone's post for some reason mistaken it for yours....
Lemme add that from the looks of the picture, you have 2 video cards on liquid with the cpu correct?
Perhaps another radiator would bring temps down without the need for a bunch of upgraded fans. It appears that you lack surface area for the amount of heat being added to water delta. Tubes warm?
Infinite66 if you think that FX-6300 is too hot when pushed up toward 5.0Ghz then you really are in for a shock when you try to push that 8 core cpu. It is worse by a factor of seems at least 30% or so. I have no idea how adding only two cores can get that much extra heat, but it seems to do so. Boards that struggle with an 8 core seem to do at least fair with a 6 core so there is one heck of a difference in only two cores.
Now me I do n0t panic or get overly concerned if P95 Blend bumps 63c, since most other types of computer use never load the the thing down that bad and thus never expect in half normal use to ever see that 63c bump.
Did you see that 9 / 10 FPS increase at 5.0Ghz? Most of the games still respond some to cpu speed increase. So keep that in mind if you move to 8 core and cannot hold up to that 5.0Ghz speed.
RGone...
thanks for all the help though. nice to know what i am in for come octa-core
One thing I noticed and maybe you only have the system there for the pics, but sitting on carpet is going to smother that 240 rad on the bottom.
