Yea I have no idea why my 6300 wanted 1.5v for 4.8 ghz. Granted your 6350 is the "higher-binned" model of the fx 63xx line. I'm loving this new cpu though.
CPU - FX-8320 oc'd to 4515hz
OC - 1.4v cpu/1.25v cpu-nb 215FSB, 21 multi
MOBO - ASrock 990fx Fatal1ty Killer
RAM - 8gb Kingston HyperX 1600mhz @ 1480mhz
GPU - Sapphire Radeon HD7770
PSU - CM TX700
CASE - Lian Li PC-62 modded
COOLING - Hyper 212 EVO
CPU TEMPS - 20c idle/ 40c gaming load
SOCKET TEMPS - 34c idle / 45c gaming load
" bob4933" that is a very informative signature. Tells the story from the get-go,
RGone...
Hey everyone. I finally upgraded!. Got my hands on an fx-9370 for $120. I forgot I had a logitech g13 gamepad I bought a while ago and haven't used all that much. Check with microcenter, and it had a warranty! Returned it for $80. Was originally gonna get the fx-8350, but the 9370 was only $20 more, so I figured I would go for the higher binned chip. Anyhow, this is a pic of 20 minutes of prime95 blend testing. This is with fans attached to NB and VRM heatsinks, as well as a fan on the rear of the socket. I was able to get 5ghz stable at 1.55v with 100% LLC (no wiggle room, remember ASrock boards are backwards) but the CPU started producing illegal sumout errors after 6 minutes of p95 testing.
hahaha after being yelled at by you guys enough times, I figured I would just make it simple xD
On occasion I do bring her up to 5.0 for some activities. Need to up the voltage to 1.425, but thats only to account for vdroop. I think on a better board I could 1.4 all day @ 5.0. Im stable at 1.3875 but sometimes it does have some droop that brings into the 'unstable' side of the house. Only downfall to this mother board honestly.
SO you can run stable at 5.0 with 1.4v?? That would be the best FX we have ever seen in this forum if that's the case.
Am I the only one that noticed this? Even with fans on the VRM section 29c difference!!! Me no likey!
Really not sure how I offended you or why you feel the need to patronize me, but I'd appreciate a stop to it.
Last I'll post off topic in this thread, my apologies for trying to be aloof apparently.
(edit: before the cries come out, I had accidently closed HWM before finishing p95, so thats simply an after the fact HWM shot)
Yes but normally putting fans on the VRM and Rear of the motherboard will help this issue. Usually when fans are added the difference is 10-12c. Infinite already has fans on the VRM and NB section, so it is concerning to me. I also have never seen that great of a difference between the two.This seems to be a frequent happening with the FX's lately. Doner had the same problem with his 8350, with no apparent cause or fix (to my knowlede), perhaps send him a pm.
lol need my coffee apparently
I completely forgot about my voltage offset, setting was as 1.425 on my bios settings, but the offset brings it up obviously.
LOL how did I manage to become a target hereThat's all good Bob no offense taken. We all do this once in a while, though I think Manny does it more.
I know no worries.you know I'm just funnin ya Manny
