Ok i thank you for all the advise here and i will be doing as you say very soon. I ran into some problems with the Ethernet card. It burn out some how going to need to send mobo back in to have them fix it. I even flashed bios still can seam to get a valid IP configuration. sort of weird. Even after flushing. Even changed the modems. I am going to add a tank cooler to the system so that i can get the temps down. should be able to do that for maybe $200. Trent as you said 60c with prime95 is going to be the goal. I think i just over looked some key things for this system. Its a learning experience for my first build. At least I got some good parts to work with and some good teachers here. I will make a "sig" next.
