I agree. My PA 160 is on par with a PA 120.2. I was told this by Cathar himself via email. Of course I don't categorize this as really good cooling but it should be sufficient for something.Yes, I would say you have "really good cooling". I don't think most bother to look up what is in the posters signature like yours, "Drake".
EK Supreme HF/ Thermochill PA 120.3
Jingway dp 1200/ EK Multioption Res 2 advanced.
That is not a weak H-100 water cooling setup for sure.
RGone...
What voltage do you recommend? I was thinking that since that is the turbocore speed and the stock VID that it might be sufficient.4200mhz @ CPU Voltage: 1.35v <<< That Vcore would not be Prime95 Blend stable. I doubt it works for Folding either.
I would take a guess that you will need 1.4V on an 8 core for F@H for anything past 4Ghz TBH.
so does that mean they don't like higher clocks? or just more volts
peaked my interest hate to rob the op,s thread..
Did a little g00gling and it seems the leakage idea began at least 8 years ago. The article here is said to explain what the leakage is. http://www.anandtech.com/print/1611
I am thru messing up the OPs thread.
RGone...
I had my 1100T @ 1.45625v stable = I hate guesstimating but my guess is that in the long run the FX processors put out at least twice the heat of that 1100T at the same speed and that is what comes around an bites in the long run. And once the cpu speed of an FX processor exceeds about 4.0Ghz the current demand thru the VRMs has to be going up rapidly or the things would not just 'cream' so many cheap motherboards with weak VRM circuits.
As a matter of fact the push to run 4.2Ghz might better be put off until you actually know that you can obtain F@H stability at even 4.0Ghz. I have jumped to the faster speed a few times and sent myself around in circles because I did not incrementally clock up. I would have found the problem far faster by moving up in mini-steps instead of going for that number I had burned into my head. But heck that is me.
RGone...
