- Aug 16, 2009
5. As in #4 above that board is likely that good for an 8 core cpu providing the bios gives FULL support for the cpu. Now there is one serious caveat about that motherboard if I rememeber the details from a year and a half ago and that is there is n0 disable APM bios setting on that motherboard and the huge draw of power thru the VRMs will cause the OCP circuit to throttle the cpu. Now this part is the best I can remember about the CHlV and 8 core cpus. There are some workarounds for that cpu throttling but you are not there yet maybe.
RGone...
I'm just leaving for work but can boot into bios on my little rig and check what's all there to be disabled when I get home later today and post some screen shots of the bios if that will help. Not sure if the bios will match up with that of blacklists though as if my memory is right the bios for the FX CPU is different and will not work for the PII's as I have my 1090T on my CHIVE.
