bmilcs, once again I feel you should go and read the guide to overclocking that Johan linked to you in the first post you made to help you overclock. Then you need to put everything back to stock, shut off all the power saving features such as Cool and Quiet, C1E etc. Then start by bumping the multiplier .5 and test 20 min prime if you don't lose a worker, freeze or bsod then bump it again .5, rinse and repeat. When you start having issues you need to start adding Cpu V core. Just keep the cpu temp below 70 and the package/socket temp below 60.
Overclocking takes patience, if you are just going to try and input settings you read on the internet, you will find more times then not you are going to be frustrated. Even if the components are exactly the same, they may not react and respond the same way. If you really want to learn to overclock and see what your chip can do you need to take your time, take good notes and listen to the people here trying to help you.
EDIT: I believe Rgone said it in your last post and Thor mentioned it in this post, your board isn't a very robust board for overclocking. You may find that you aren't able to overclock on it at all.
