- Apr 6, 2013
- Thread Starter
- #41
So you jumped from 4.0 to 4.2?
Yup. Sorry I'm not being as thorough as you liked. I only had like an hour to mess around tonight.
How does that look though so far?
ASRock 970 EXTREME 3 = 4+1 power phase.Not saying you cant overclock, but just something for you to consider.Not good for pushing high overclocks.
You have to understand that there is a method to our madness. We say what we say because we cannot be at your pc doing it ourselves. Not being able to limits us from being able to understand what is going under the hood. As the two post above suggest and what I said earlier is still important, you may not be able to push that board no matter how much v core you throw at it. What I feel you should do is stop where you are and run prime for 2 hours at 4.2 and see if it is stable there. If it is then proceed with what you're doing.Yup. Sorry I'm not being as thorough as you liked.
You are correct "Wipeout" and the Asrock 970 Ext3's have been one of the prime offenders at being a real pain in the rear to get to overclock only somewhat from day one. I see from this thread that the boards have not changed any over the course of a year and a half.
Those boards being cheap is just what they are...cheap. Sadly Asrock has some good ones but the users always opt for cheap and the nametags like Extreme3 and 4. The Asrock Fatal1ty 990FX and the 990FX EXT9 that seems to have replaced are likely awesome motherboards. The Fatal1ty is for sure.
Sadly also Asrock had 990FX EXT 4 boards with good paper-specs and we have not seen a single one of them come into this forum section in the possession of a single owner. Nothing but the elcheapo 970Ext3 and a few 970Ext4s.
I don't think there is a single thing wrong with the 970 cheaper chipset as delivered from AMD. I think the cheap chipset as utilized with surrounding cast on the boards has been abysmal for overclocking FX processors. Asrock took cheap to heart and made a cheap board and got a lot of buyers that now cannot do nearly what they could have with other better motherboards. That is the kicker. A kick in the seat of the pants that you cannot adjust or buy CPU coolers or whatever to get away from. Only a board like the Asus CHV, the Sabertooth 990FX, the Asrock Fatal1y (now EXT 9 likely), the Gigabyte UD5 or UD7 boards. Only those boards that you pay for really have a pretty good overclocking history. A shame is all I can say.
RGone...
You are running your ram at 800mhz, did you know this?
Taking your time, having patience, especially when you are new and taking good notes of every change you make will help you learn.
With all that said, please post a CPU_Z Spd and memory tab so we can see if your timings are correct and what the spd profiles are on your Dram.
b milcs, 1333 ram will hold you back, after you find your cpu clock these guys will help you get the ram clocked and that will improve things also.
to help improve the game time and keep what we've got, go into the bios and disable 2 or 4 cores, this will let you clock the other cores higher and keep the game time fun.
There are many bmilcs! My Bluray software will use my FX8350 and 2 GTX 580's to 100%. C_D has some program that he runs( at least I've heard rumours) that will run for days fully utilizing the CPU. F@H, the list goes on!! Depends on what you're in to.
So how bout some pics!!
