- Jul 12, 2007
i currently have a Biostar A880GZ but its minimum memory voltage that will run on the motherboard is 1.6v @ 1333MHz, which is doing no favors for G.Skill ram rated 1600Mhz @ 1.5v.
But before I test stability with this cpu/mobo/ram combo, i want to keep my mobo options open just in case issues arise.
what is a good budget one?
min requirements:
$100-$150
Sata III
onboard video (any)
FX ready, meaning the CPU will post/boot out of the box and no BIOS update is required.
min memory voltage <= 1.5
i've done a bit of research and most seem to suggest its stable to use them together.Biostar: A880GZ is compatible with Patriot, G.Skill, Crucial, Corsair, OCZ, Mushkin and Kingston DDR3 memory.
Me: Is it compatible with DDR3 memory that runs at 1.35 volts?
Biostar: The motherboard minimum voltage is 1.6 volts. *You may purchase 1.35v memory, but it will run at 1.6 volts on our motherboard.
min requirements:
$100-$150
Sata III
onboard video (any)
