- Jan 11, 2012
- North Carolina
is turbo boost on by default? or is it a feature that is turned on manually to overclock?
Yes, turbo is on by default, and you should turn it off in the BIOS before you overclock.
what about 960T?In the case of the FX-4100, it disables one module to cut it down to two cores, raises the multiplier from 18 to 19 to achieve 3.8GHz, and raises the voltage to 1.32 or 1.33 volts (Which in my opinion in unnecessary anyway because my processor can do 4GHz on all four cores at stock 1.25V stable). Obviously it's easy to overclock all 4 cores past the 3.8GHz/2 core turbo mode.
what about 960T?
i mean is it 'fake' quad core like the FX 4100?As far as I can tell, it doesn't have a turbo mode.
what is a good budget one?
Don't know if you settled on one but I saw some discussion of M5a88-m vs. M5a88-V. there is a big difference beyond features: the M5a88-m is an M-ATX form factor. Kinda important if you have and like a microATX case, as I did and do.
I needed mATX and i have a preference for ASUS, it was budget and decent PhenomII's were/are no longer in the channel so what do ya do for an FX-4100?
'Budget' being the watchword, M5a88-M it was.
My experience so far says it's a very decent board, at face value, with all the needed features to keep it relevant in the near future: 6GB SATA, USB3, GB ethernet with IPv6 support, HD audio on-board. Who cares about the onboard video: I paired it with a GByte HD6670 for those few 3d gaming forays I enjoy.
And it's ASUS, so it's rock solid and as far as 'face value' goes it shows, but we want more than that so we 'custom tune' it. OK just say it: overclock the snot out of everything. That's where this board's weaknesses start to show (duhh).
I can't make it stop throttling! Turn off all the CnQ, C1e, C6, everthing I can find and it still cuts back when OCCT fires up the cores. From what I can tell this FX throttling is controllable with newer BIOS's on less- budgety boards. I don't know if it's true on their somewhat more overclocker-friendly M5a88-V-EVO but I wish they would here too. It's very aggravating to think ASUS would abandon this board, if they are, just as the community is realizing that what makes FX's shine is to exploit latent core speed headroom.
My only choice is to bump HTRef: I'm at 260 now. with a mult of 17.5 it throttles back and forth to mult of 16.5 but runs OCCT, medium data set, stable and this on a stock PhenomII cooler I got. Gets warm (64C/58C on cores), but I'm good with it just for the stress tests. It stays at 4.6G rock stable and bearable temps (low-40's core) running 3d demos (3dMark11) hours on end so I'm content with it as a 24/7 for what I do with it... which isn't running power viruses like OCCT or Prime95.
But my prob is this: I have no idea what voltages are really doing! Everything is telling me something different and NOTHING agrees with what the BIOS says! I set it up with a very modest CPU core over-volt to 1.375 but CPU-z tells me it's like 1.48! I honestly think the BIOS is just plain wrong. GROTESQUELY, and very dangerously, understating actual voltage to the CPU.
But what do I know I am OC'g newbie, and this is my first post here so...
I'm hoping someone has suggestions: have others tried this board and found the voltage readouts to be flaky?
Could this be a power supply issue, realistically? I have a very good, if old, Antec True Power. It's 330w rating is obviously short of recommendations, but the busses (12v and 3.3v most noteably) are staying very stable as the load increases with just very tiny sag in hundredths of a volt. to help keep things stable I've increased VDDa to 2.6 volts from BIOS stock 2.5; I heard that helps with VRM headroom.
Any suggestions from smart folks? If nothing else, I would just like to know if I'm doing OK with my overclock to 4.6G on a stock PhenomII cooler!
Read this thread for FX throttling issues. There's a nice fix posted somewhere near the end. You have to download the fix, set up a .BAT file for it and drop it in your startup folder, and it eliminates the throttling issues. The voltage issue I was also having a problem with. Even at stock, mine was reading 1.32V, and when I tried to correct it in AMD OverDrive and I ended up with 1.44V I changed it in the BIOS (and actually undervolted) and then it actually stayed where I wanted it. Just to make sure you're adjusting it right though, you have to set your CPU/NB is set to MANUAL and not OFFSET, and then you can adjust your voltage. Link to my embarrassingly noobish thread about it.
....Maybe it's load-line calibration?? dunno how it works... but it sounds like something that would fluctuate volts a little...
Load line calibration is what I thought before, but it was giving me a constant voltage even at idle. DO NOT USE CPU OFFSET TO ADJUST VOLTAGE!!! Turn CPU/NB to manual and it will reveal the actual voltage control. It remains hidden if CPU/NB is set to offset.
I thought load line clibration and cpu/nb offset covered voltage droop, am I mistaken?
