Hi,
i7 8700k
4.7GHZ
1.285VCore
LLC 3 (Under full load in prime 95 CPUZ reports 1.272 Corsair Link reports 1.27)
I am seeing temps of 85C after only 30 minutes of prime 95 (Small FFT for max heat)
My corsair H115i is mounted in the top of a Corsair 750D Airflow edition
the fans mounted in pull at the top of the case (pulling air into the case)
the ambient temp in my basement is 19C or less
the loop water temp is 29.1C I do have the fan curve set to quiet so at this temp the fans RMP are only 1600
I am new to AIO liquid coolers but I was expecting better temps from this, I was just wondering if this is to be expected or not?
Thanks
i7 8700k
4.7GHZ
1.285VCore
Thanks
