Guys, I have spoken to Danny (seems I do so on a regular basis) yesterday. He is aware of the base problem and is now lapping each one himself on his lapping machine. No help for those of you with some bad bases, but he does listen to you guys! He is fixing the problem. The other thing you guys MUST understand about the WW is that (NeoMoses) yes the copper stock is pretty flat when raw, but, machining the fine channels really heats up the block, and as the block is so thin, they can become concave, convex and even warp from this process. Nothing you can do about that, and many blocks end up in the trash because of it.
Also, if you lap your WW, make sure not to get it too hot doing so, if you do, this could warp the base. Definately use water on the paper and go slow. Machine marks are far less of a problem (unless severe) than a convex/concave base.
