- Apr 13, 2004
- Joint Base MDL NJ
So I have an Asus Crosshair IV Formula and as many may know they have notoriously had issues with NB heat. I originally had a 'good' version with no heat issues but had to get another due to some damage when I shipped it over seas. Of course, karma struck me and the 'new' one had the issues. So I replaced the stands offs of the new board with the old as I had read that that was the issue when it came to NB heating issues. Unfortunately that didn't seem to help since I will often get temps of 55c while gaming, it will even hit 60c from time to time, this is with the entire system at stock speeds so I can't even consider OCing as I am sure my temps will soar.
Looking at the stock heat sink it looks like a bad design to me, as they attached blocks to the bottom to make contact with the NB and SB rather than the heat sink sitting directly in contact. So I am looking at putting some heat sinks that I 'salvaged' from another board onto the NB and SB via arctic thermal adhesive since the mounting holes don't line up with the MB. My main concern though is that I don't have a replacement solution for the VRMs that the stock heat sinks covers. So I am looking to crimp the heatpipe that goes from the VRM heat sink to the NB heat sink, which also continues to the SB heat sink, and then make a cut to allow the new sinks to sit in place. Will this work or will it completely bork the heat sink's ability to cool my VRM?
This is the stock heat sink-
-Seabee
-Seabee
