- May 31, 2003
- Never Never Land
OK I've narrowed down to "where" to buy my next watercooling kit. They carry Swiftech and DangerDen. So I'm left with a few options here. You see the thing is I want the best water system I can get for the least amount of money with the choices that I have at this online store..... http://www.vibecomputers.com. It's near where I work so pickup is easy and convenient. They carry everything I need for a complete system so I don't have to drive across town to pick up individual items. All I'm asking is for some expert advice on the following with a brief explanation for your decision. I don't care about mixing and matching parts.
*ALL PRICES IN CANADIAN DOLLARS*
CPU Waterblock:
Danger Den Maze4 $56.95 vs. Swiftech MCW5000-P $49.95
GPU Waterblock:
Danger Den Maze4 $64.95 vs. Swiftech MCW50 $44.95
NB Waterblock:
Danger Den Z-Chip $47.95 vs. MCW462-UH $74.95
I'm not sure if the MCW462-UH will fit on my NB properly. (see sig.) It says it's universal. Can anyone confirm this?
Radiator:
Swiftech Radiator 676 (Dual 120mm) $59.95 vs. Black Ice Xtreme $89.95
Water Pump:
Swiftech MCP300 $49.95 vs. Hydor L30 $64.95 vs. Eheim 1250 $93.59
What's recommended? Easier to use?
Reservoir $26.95-$39.95 vs. Switftech Fill and Bleed Kit $29.95 vs. T/Y Fitting $2.49 vs. None of the above $0
On a side note. I have 10' of PVC tubing. 1/8" thick, 1/2" ID and 5/8" OD. I think it's rated at 30psi or something like that. Is this stuff good enough or should I get some Clearflex 60?
CPU Waterblock:
GPU Waterblock:
NB Waterblock:
Radiator:
Water Pump:
