Ok well im kinda stuck trying to overclock my CPU
I have a ASRock G31m-s R2.0 and it has minor overclocking ability's but im kinda stuck at 3.1GHz and going higher makes my system hang after the BIOS and it beeps like 50 times until i shut it off.
If searched/posted everywhere for help but no ones seems to want to, so forgive me if i kinda makes this short with not enough details, just remember ive typed almost this exact thing alot today and am loosing hope of getting help. If you do need more info then tell me and ill most defiantly get that for you right away
I cant find a voltage control for my cpu which is what ive heard can fix hanging. And my motherboard has 2 options to overclock, CPU PCIE ASYNC AND CPU PCIE SYNC Ive been using sync cause it syncs the PCIE option with it so i doint know if thats whats causing my problem or not. Also Im beyond new to cpu overclocking so bear with me if i makes some mistakes with words and such. I Dont have money for upgrades right now unfortunately. though i do plan on getting a 2500k ASAP but ASAP = Long time for kid without a job and less than fortunate parents.
So my specs are
Intel E3400
ASRock g31m-s r2.0
x1 2GB ddr2 800 x1 1gb ddr2 800
80Gb 7200RPM boot hdd and x2 150Gb in raid 0
GPU XFX radeon hd6770
I did build it 100% by myself no help
According to CPU-z my OC settings are:
The multiplier is 13 Locked of course
I adjusted the bus speed to 240 going to 241 gives me the beeping after bios thing
The Core speed is 3117
Rated FSB is 959 I dont know what changed that TBH it used to be different
So my specs are
Intel E3400
ASRock g31m-s r2.0
