Hey all,
I just stumbled upon this forum trying to find out how to overclock my system.
Currently i have a Abit NF7-S v2 and Athlon XP 2500+ (Barton core) with OCZ 2x 512 MB PC3200 running in dual channel.
I know that in bios i can select 2500+ or 3200+. However if i put it on 3200+ my system is not stable, mostly i get CRC errors from zip files and what not. My memtest86 showed that my memory is ok so i don't know what's going on.
When i put up FSB to 181 and left the multiplier at 11 and its been running stable (ran prime95 for 3 hours with no errors).
I looked around the forum and found modified BIOS'. Which one should i be using? I don't use SATA...and i just want to be able to run a bit higher speeds.
I have a CPU heatsink..but have no idea which one it is...runs at 4300rpm all the time though.
What do you guys suggest? Merlin's BIOS?
Thanks in advance!!
Thanks in advance!!
