- Thread Starter
- #41
I had heard a odd noise from the pump for about 3 sec and then it stopped...my hoses are setup like the 2nd picture..one hose is cool and the other hose is warm..
i`d turn it around so that the pump doesn`t pull the air from the top of the rad.
results? better/worse/meh?
Don't take that package "Powers" too seriously. It is not actually a measurement but a calculated estimate by the software.
Something is still very wrong with your water cooler. My suggestion is to hang it so the radiator is higher than water block, the hoses are straight up and down or nearly so and the hoses are at the bottom of the radiator. Hang it like that overnight and give the air bubbles a chance to work out of the liquid and travel to the top of the radiator. Then check it again tomorrow.
No, it's too hot. Even when there's not much load on it I think. I wouldn't conclude you have a faulty board or CPU just yet. It is obvious your temps are way higher than they should be.
Well, if the temps aren't improved significantly after the cooler has been burping all night while hanging then the cooler is bad and you need to do an RMA of the cooler I would think. You never answered my question about having the stock air cooler laying around. If you had that and put it on you could check those temps against the temps you were getting with the water loop.
