Help required with a strange PC issue
Rookee
I hope im posting in the right section. Recently ive bought a new system for my sister. Its a fairly decent config.
Intel i5 650
Gigabyte GA-P55-UD3
1 TB WD SATA Hard Drive
2 x 2 GB DDR3 1600 Mhz G skill Ram
1 GB Gigabyte Radeon HD 5750
Lexa Blackline Case
Linksys Wifi PCI Adapter
Coolermaster GX 750 W PSU
Ever since the pc was built there have been stability issues. I installed Windows 7 Home edition 64 bit on the system. Starting from the 2nd day itself there were problems.
Very frequently windows would refuse to load past the 'Windows Starting screen' and would freeze there. Only a system restore and a couple of times a clean reinstall would get me past this.
Sometimes after a restart or a shutdown about 2gb+ of the total 4gb would suddenly become hardware reserved. At 1st i thought faulty ram and ran the 2 modules seperately and ran memtest on both modules seperately and together. Both passed serveral long tests. I finally updated the motherboards bios from version F5 to version F7 (which apparently has enhanced memory support). Finally the memory related problems ceased (like almost 2000+ mb of ram becoming system reserved), but the windows getting stuck at loading etc continued happening.
Off late a new problem started - There would be no display. The computer would boot (you can even hear windows startup in the speakers) but absolutely no display. Not even BIOS or POST screens would display inspite of successful boot up and windows loading. This led me to believe a faulty graphic card so i unplugged the graphic card and plugged it into my other computer (its an E8400 with a Gigabyte P45T-UD3 Mobo and 8 gb of DDR3 Kingston Ram, and it normally runs a Radeon HD 4870X2). On this computer the PC fails to boot completely when i plug the Radeon 5750 which i beleived to be faulty.
What i cannot understand is that on my new computer with the 5750 the computer boots but there is no display (the thing to note is that sometimes the display is normal but sometimes there is none). On the other hand when i plug in the 5750 in my old computer the PC completely fails to boot. There is 1 Long beep followed by 2 short beeps which according to the manual indicates a faulty Video card.
Anyhow i took the gfx card to the store where i bought it from and he tested it and it ran fine on his test bed. Needless to say i was a bit confused. To do a bit mroe testing i bought a cheap Nvidia 8400GS on my way back and tested the new computer with this card and it runs as stable as any computer . As soon as i plug in the 5750 the display problems start. Sometimes the pc boots as normal with display and evrything and sometimes there is no display. And on my older computer it completely fails to boot still.
Im at my wits end as to what the problem here is. Im inclined to beleive that it has to be the gfx card for 2 reasons. One that the 8400GS runs stable on the new comp and second that the 5750 on my older computer results in boot faliure with a long beep and 2 short ones. But the store person says the card is fine and wont replace it or send it for repairs.
Any insight into this will be highly appreciated.
i would lean towards the gfx being bad OR your PSU isn't up to par with what the needs are..if earthdog pops into this thread he could fill in for the psu better than I
Another thing i forgot to mention which may or may not be relevant is that my gigabyte 5750 is recognized in both the device manager and dxdiag only as 'ATI 5700 Seriec' and not specifically as 5750 which i would expect. I dont know if this is normal or not. Yes i have downloaded and installed the latest drivers from ati's website.
thats how those apps see vid cards.. all ati cards if im not mistaken will show like that except for some of the specific high end cards, which i think actually show their full # set
GPU is definitely an issue, but I wouldn't be me if I didn't look at the PSU funny. We don't trust thermaltake/cooler master/etc around these parts.
Those companies might have good cases to peddle, but I wouldn't trust their PSU's.
Also, what city and state are you in? I'll gladly pay this store a visit for you if it's within range. if you just bought this PC and they're refusing to honor a refund, you got a serious fight on your hands.
