Looking for a performance boost over the E6300 and a nice OC'ing, I bought a Q9400 and Zalman CNPS9700 HSF the other day. These are on an Asus P5Q P45 Mobo, the one without the fancy heatpipe cooling system. Ram is Kingston 2x2GB DDR2 1066 5-5-5-15-2T.
I can't get a stable OC higher then 410mhz FSB with all on auto other then the ram voltage set to 2.2v. Ram is at 1025mhz 5-5-5-12-2T. Vcore is at 1.392 at full load when set to auto in BIOS.
With these settings, Prime 95 Blend test have temps at 66deg with the HSF on low, and 62deg with the fan on high using Core Temp - Core #0.
I've played with all the settings after spending a few days searching on forums for ideas but nothing is more stable then with the auto settings. It's failing in all sorts of ways, BSOD, Prime95 Blend and In-place, and OCCT.
With the FSB at and over 425 it always seems to fail much more quickly in 'Blend' (within a few seconds), then slower in 'In-place' and sometimes stable with 'Small FFT'. This would lead me to think there was a higher load on the chipset when more load is being put on the RAM. It still fails if the RAM is set to around 850mhz.
I can get Win7 32bit to boot at 440mhz FSB and run Prime 95 Small FFT successfully with the core at 68deg at these settings. Both other Prime95 torture tests fail on several cores within seconds:
FSB: 440
DDR2: 881mhz 5-5-5-15
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
Mem OC Charger: Disabled
Ai Clock Twister: Light
Ai Transaction Booster: 11
VCore: 1.39375v
CPU GTL Reference: Auto
PLL Voltage: 1.56v
FSB Term Voltage: 1.28v
DRAM: 2.0v
NB Voltage: Auto
SB Voltage: Auto
PCIE SATA Voltage: Auto
LLC: Enabled
CPU Spectrum Spread: Disabled
PCIE Spectrum Spread: Disabled
CPU Clock Slew: Auto
NB Clock Slew: Auto
CPU Margin Enhancement: Optimized
Ignore PCProbe temps.
I've ordered a Zalman NB cooler and 40mm fan to assist there, but this chipset should be good for at least a stable 425mhz.
Any ideas on settings or changes would be appreciated.
Thanks
Brad
FSB: 440
VCore: 1.39375v
PLL Voltage: 1.56v
DRAM: 2.0v
NB Voltage: Auto
SB Voltage: Auto
LLC: Enabled
NB Clock Slew: Auto
Thanks
Brad
