Hey Everyone!
I have read most stick's on various forums and researched a lot about most parts Ive looked at but i am still a little confused about some things
like the pump Ive looked at Hydor L30 II 1200 L/ph 240V like the name say it requires 240v but my research say that a PSU only give 12v was very little
information on that part might missed it tho PSU i have is a CORSAIR HX 750W 80+ SILVER..
so how to use that pump? some reviews say a controller is included but nothing if it transform the 12v from psu to 240v :s
also is that pump more reliable and have better performance then Alphacool TPP644 Laing D4? or do you know a better pump that is "The ultimate" pump to recommend?
i am going for a silent build meaning water cooling Everything Mobo. ram. gpu, cpu so Ive gone for the Coolgate Quad 140mm Ultimate Heat Exchanger Radiator
in the bottom compartment and a Coolgate Single 120mm in the top of my TJ11 and maybe dual loop if that is not enough what do you think?
the reviews on those rads ive read say that they are good for low - medium fans or do you know anything that would cool better?
also which tubes would be best 1/2 or 1/4" the smaller one in my math would be more flow restraint but i can be wrong? i have thought of going 1/2 unless you recommend otherwise.
Sorry for a long post but i wanted to give as much information to you as possible which makes it easier for you to respond more accurate.
Best regards Naala
Best regards Naala
