- Jul 30, 2013
if you really want some great airflow you should look at delta fans at 30$ you can get a 120 mm that pushes 240 cfm at max the only downside to it is well you might think you live next to a tarmat but hey you asked for airflow. im looking at overclocking the same as you and will have a setup with a:
SILVERSTONE HE02 CPU Cooler 80$
with a delta fan attached to push the air straight up because that is how the heatsink is designed without a fan on it it keeps temps down very well once you get a delta on that thing your temps will have a good chance at being about room temp at idle and prob around 40 c at load to 60 c depending on your processor and how high you oc it. anyways yeah I also have 6 fans in my case along with that delta.
if any of you think this is a bad idea please tell me and I will either shut you down hard or thankfully accept the advice.
