- Feb 18, 2002
My problem from here has turned into a potential power problem, so I reposted in this section.
I am using a UPS Battery Backup (specs below.)
1. To it I had a cable DVR box connected. It died (power on - nothing happens.)
2. LCD connected to it developed an infinite power on/off loop.
3. Now a PSU connected to it died today.
How do I find out if this is a triple coincidence, how do I test if this UPS Battery Backup is a serial killer?
UPS Battery Backup
Back-UPS ES 500
APC 500VA300 W BE500U
Technical Specifications
Output power capacity 500 VA
Output power capacity 300 Watts
Max Configurable Power 500 VA
Max Configurable Power 300 Watts
Nominal output voltage 120 VA
Input voltage range for main operations 96 - 136 V
_____________________
AMD Athlon XP 2500+ AXMH 2500 FQQ4C
IQYHA 0348 SPMW
2 x 512MB Centon PC3200 (Samsung chips) @ 9 4 4 3
[200] FSB x 12 = 2400 MHz @ 1.85 Vcore with memory frequency at 100% [200 FSB] @ 2.90 Vdimm and 1.8 Vdd
Epox 8RDA3+ v2.1, BIOS 07/29/2004
Thermalright SLK-900A with variable speed 80x25mm Thermaltake Smart Fan 2
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower TP380
Four 80x25mm Case Fans + 1 Variable speed 80x25mm Fan YS-Tech FD1281259B-2F
UPS Battery Backup
Back-UPS ES 500
IQYHA 0348 SPMW
