c627627 said:After a night of charging, brand new APC model 725VA425 (425 Watts):
123.3 V
and
73.2 V battery powered.
Hm....
orionlion82 said:HOLD IT!
and the idea im getting here is that APC or whomever is using cheaper "non-pure-sine-wave" or "modified sine wave" or "square wave" inverters is absolutely unexcusable when talking about computer equipment.
as a matter of fact those inverters are for everything BUT computer equipment!!!
SavageBasher said:Show me a computer component that runs off of ac. Show me one thing. If you knew anything about computer supply, they are just transformers. Sine, square, or sawtooth, its all getting recified and buffered with caps. Doesn't make a damn difference, as long as it is within voltage range and frequency. It's always dc at the end.... square ac waves are most harsh on incadescent lighting and ac motors.
soulfly1448 said:Dead battery would be the first thought. My question is, why do you need a UPS on your home unit? I've seen so many posts about UPS's destroying eqiupment.
c627627 said:Meanwhile, what do you think about their explanation, that new out of the box UPS may show low voltage "initially." Then "after it's used a bit" it's supposed to show voltage in the hundreds.
orionlion82 said:wheres the little gif with the BS flag?
Gautam said:I'm in the same boat basically.
Which APC unit do you have? Could you provide DMM readings?
