- Apr 19, 2012
Ok back on topic, back when the FX9590 came out I got 1 and went through 3 coolers, 2 air and 1 water (V6GT, V8GTS and Nepton 280L) all 3 failed, I lost on the silicon lottery, the Nepton 280L lasting the longest under load.
I then replaced the FX9590 with FX8350, and the temps on the 8350 under max load maxed at 30c (30c as reported by HWM), then the pump on the AIO failed after 3 months, then swapped with V6GT with the same temps as the Nepton 280L.
So if the cooler (air or water) is not rated at or above the power the CPU is pulling (OC'd or not) then there will be high temps.
Oh man you are comparing AMD's 2nd hottest chip to a mid range considerably lower wattage cpu. Both with very different leakage characteristics.... The 1st hottest chip would be the Agena 9950. I don't think even the PHII 980BE put out nearly as much heat as the 9590 and 9950 processors. AMD even out right said to use water cooling on the FX-9590. They didn't ship air coolers with them chips for exactly that reason. The second you turn on that PC, the heat sink was heat soaked.
A super great FX chip for temps would be like the 8370E or perhaps lower ended like 8300 and 8310 chips. You could almost passively cool them ones in comparison.
79c to 81c is within margin of error. There. Video debunked. Moving on then lol.
I should just delid it
I support this statement.
