Agree with rge. Looks like my uniform brown discolored Masterkleer tubing when it had plasticizer breakdown from using it longer than 1 year.
This ^^^.
Just bad tube bro.
sorry guys i already cleanded it out and got new tubing so no pics. Also my kit came with deadwater and a kill coil from frozenpc, not PT as i thought in OP. It is a closed system not near a window or "sunlight" in general. that is why when i opend case to do some fan swapping and saw the tubes i was like....wtf?
The distiled water was walmart brand and everything was warm/hot water flushed prior to assembly. No UV lights and yes my Res is sealed.
that is why i was asking about the algea. i didnt think there should be that happening as soon as it did much less at all.
When i do my next breakdown ll have to do a better job at sanatation.
from my order history from frozen pc....
XSPC Raystorm 750 RS240 Extreme Universal CPU Water Cooling Kit (New Rev. 4 Pump Included) w/ Free Dead-Water!
no guys this is not bad tubes. this is green algae that had turned brown after i had tryed to kill and remove the growth with bleach. i had to break down my loop because my psu went out this last week and when i get my new psu im going with just my kill coil. and by the way that set of pics was from 3 months of use.
UV kills algae, I have UV's in fresh water tanks and in 50k gallon outdoor ponds. It causes the algae cell to rupture, the dead cell turns brown and may cling to the wall of the tubing.
That's not exactly true. The sun releases UV, plenty of which makes it to earth's surface, but algae still exists on the surface of earth - so UV doesn't instantly kill algae. UV can kill microbes in sufficient concentration, but my understanding is that that concentration is high enough that it's impractical for our purposes.
Bottom line, UV light in a computer case does not cause algae, but other visible light can/will cause algae.
I misunderstood your assertion. I thought you were trying to say that UV would help reduce algae. I completely agree that it won't contribute to algae growth.
UV light is used to kill algae and has been for many years in the aquarium industry and outdoor pond industry.
Yes, but we are talking about computer WC and not the aquarium industry or the outdoor pond industry.
It's still moving warm h2o in tubing and dealing with algae. Except in a puter you can use chems and bioicides.
Yea, but there's a tremendous difference in scale for any sort of personal computer cooling.
