- Mar 30, 2003
- Belgium
[hwbot] applicationname ranking
WPrime 1024M Ranking
WPrime is a quick and easy way to measure your processor performance
download here
Rules
- don't use multiple nicknames
- only post scores belonging to you
- 1024M calculation only
- use the online submission function of wprime
Guidelines
- format your score as follows: [hwbot] score - system description [/hwbot]
- try not to use abbreviations. eg. 'opteron 146' is ok, '146' is too short.
- format processor overclock like 'A64 3200+ @ 2850Mhz' or 'A64 3200+ @ 2.85Ghz', format videocard speed as 'R9800 @ 350/333Mhz'.
- allowed score formats: '120.34' or '120.34s' or '120.34sec' or '1m 120.233s' or '1h 1m 120.233s'
- don't use text layout (bold, italic) or hyperlinks in your system description.
bot info
moderators: Maxi
members who changed team: kaz_girl (The Raptor Pit), miahallen (Team IRONMODS)
options: update ranking now
team ranking - hall of fame
rank - top 10 average - team name - weekly & monthly rankchange - links
1. 148.00 i4memory.com - ~ ~ - website - forum
2. 149.99 Bench Tec UK - ~ ~ - website - forum
3. 150.28 H.O.T. (Hellas O/C Team) - ~ ~ - website - forum
4. 152.30 Madshrimps Belgium OC Team - ~ ~ - website - forum
5. 155.94 JMax-Hardware - ~ ~ - website - forum
12. 171.70 HardwareLuxx Germany - ~ ~ - website
13. 175.45 OC Forums - ~ ~ - website - forum
14. 177.18 "Overclockaholics" - ~ ~ - website - forum
member ranking - hall of fame - more
generated by hwbot - http://www.hwbot.org - [email protected]
download here
Rules
Guidelines
bot info
moderators: Maxi
- 1. Qartweli (Overclockers.ge) - 14.23 - no description
2. kolarik ([OverBR] Overclock Team) - 42.73 - From Brazil
3. Krohpit (Russian Overs-Overclockers.ru) - 77.36 - two dual channel memory node
1. Deanzo - 2min 30sec 690ms - Core i7 Extreme 975@5005mhz - Core i7 975 @ 5005MHz
2. pauld5999 - 2min 32sec 250ms - Xeon [email protected] - no description
3. mgoode - 2min 43sec 120ms - Core i7 960@4750mhz - core i7 960 on h20
4. Ross - 2min 48sec 80ms - Core i7 920@4493mhz - Core i7 920 @ 4493MHz
5. rdrash - 3min 0sec 560ms - Core i7 920@4254mhz -
6. Brolloks - 3min 4sec 830ms - Core i7 940@4200mhz - 940
7. Woomack - 3min 5sec 440ms - Core i7 920@4163mhz - no description
8. luv2increase - 3min 7sec 230ms - Core i7 920@3950mhz - 24/7 Stable Overclock Settings. Batch# 3841A383, , 1.282vcore idle - 1.329vcore load, , 4.15Ghz if you include the fact that Turbo is Enabled
9. dejo - 3min 7sec 310ms - Core i7 [email protected] - OCForums, dejo
10. SquashFX - 3min 15sec 20ms - Core i7 920@4000mhz - Core i7 920@4000mhz
11. henzo - 3min 17sec 40ms - Core i7 920@3932mhz -
12. ChinStrap - 3min 24sec 720ms - Core i7 920@4200mhz - Core i7 920 @ 4200MHz
13. Maxi - 3min 53sec 600ms - Core 2 QX9650 (3.00Ghz)@5238mhz - no description
14. toddm27 - 3min 57sec 250ms - Core 2 QX9650 (3.00Ghz)@5600mhz - [email protected]
15. ZL1 - 4min 27sec 810ms - Core 2 Q9550 (2.83Ghz)@4604mhz - Q9550 E0 @ 4604 w TR120EE + 100CFM - EP45-UD3P
16. ghost_recon88 - 4min 32sec 220ms - Core 2 Q9550 (2.83Ghz)@4522mhz -
17. sno.lcn - 4min 32sec 270ms - Core 2 QX9650 (3.00Ghz)@5040mhz - no description
18. glock19owner - 4min 39sec 330ms - Core 2 QX9650 (3.00Ghz)@4465mhz - QX9650/4465/Air Cooled
19. Dawgdoc - 4min 43sec 790ms - Core 2 Q6600 (2.4Ghz)@4640mhz - no description
20. automiketic - 4min 48sec 110ms - Core 2 Q9400 (2.66Ghz)@4208.20mhz -
21. Pntgrd - 5min 2sec 660ms - Core 2 QX9650 (3.00Ghz)@4050mhz -
22. baditude_df - 5min 13sec 700ms - Core i7 920@4205mhz - baditude_df -OCForums-
23. Albaholic - 5min 23sec 870ms - Core i7 920@4000mhz - i7 @4GHZ 1024m
24. MarkF - 5min 24sec 420ms - Core 2 Q6600 (2.4Ghz)@3942mhz - MarkF -OCFORUMS-: Q6600
25. Big Mike - 5min 31sec 390ms - Core 2 Q6600 (2.4Ghz)@4014mhz -
26. OnDborder - 5min 33sec 0ms - Core 2 Q6600 (2.4Ghz)@4005mhz - Intel q6600 @ 4005MHz
27. jmorgan - 5min 40sec 40ms - Core 2 Q6600 (2.4Ghz)@3908mhz - ocforums.com
28. gjwild - 5min 40sec 940ms - Core 2 QX6700 (2.66Ghz)@3900mhz - QX water-cooled
29. Cluster - 5min 42sec 980ms - Phenom X4 9850@3450mhz - no description
30. Spawn-Inc - 5min 44sec 80ms - Core 2 Q6600 (2.4Ghz)@4174mhz - no description
31. TranceBear - 5min 53sec 70ms - Phenom X4 9950 - Phenom X4 9950 @ 3450
32. dylskee - 5min 53sec 950ms - Core 2 Q6600 (2.4Ghz)@3806mhz -
33. Th3 F4ll3n P1mp - 5min 58sec 0ms - Core 2 Q6700 (2.66Ghz) - Q6700 @ 3.6
34. turkey4550 - 5min 59sec 330ms - Core 2 QX6700 (2.66Ghz)@3800mhz -
35. Mu||et - 5min 59sec 920ms - processor unknown - X3350 @ 3400MHz
36. inkfx - 6min 4sec 410ms - Core 2 Q6600 (2.4Ghz)@3916mhz - Q6600 @ 3916Mhz
37. HousERaT - 6min 9sec 140ms - Core 2 Q6700 (2.66Ghz)@3998mhz - Q6700 @ 4Ghz
38. omni - 6min 16sec 790ms - Core 2 Q9300 (2.5Ghz)@3329mhz - Intel Core 2 Quad Q9300 @ 3329 mhz
39. keepaf1 - 6min 17sec 920ms - processor unknown -
40. RangerXLT8 - 6min 24sec 710ms - Xeon [email protected] -
41. jorlain - 6min 31sec 50ms - Core 2 Q6600 (2.4Ghz)@3504mhz - Q6600 @ 1.34 vcore
42. icebob - 6min 32sec 610ms - Phenom II X4 940@3000mhz - no description
43. sp33dball - 6min 40sec 450ms - Core 2 Q6600 (2.4Ghz)@3392mhz - Q6600 @3392MHZ
44. Dolk - 6min 48sec 470ms - Phenom II X4 940@3010mhz - 3.0ghz PII 940BE 1024M
45. pscout - 6min 52sec 280ms - Core 2 Q6600 (2.4Ghz)@3324.50mhz - q6600 @ 3.324 on p5w64
46. Torin3 - 6min 53sec 230ms - Core 2 Q6600 (2.4Ghz)@3251mhz -
47. Neuromancer - 6min 56sec 440ms - Core 2 Q6600 (2.4Ghz)@3600mhz - no description
48. XTTX - 7min 4sec 360ms - Core 2 QX6700 (2.66Ghz)@3199.90mhz -
49. KONAKONA - 7min 5sec 350ms - Core 2 Q6600 (2.4Ghz)@3200mhz - -OC Forums-
50. schumi - 7min 8sec 980ms - Core 2 QX9650 (3.00Ghz)@3000mhz - QX9650 @ 3000 mhz
- 1. AndreyKV (Russian Overs-Overclockers.ru) - 627.56 - no description
2. ej52 (Guru3D) - 650.56 - no description
3. fr@me (Team MXS ModLabs.net) - 659.38 - no description
1. squirly - 12min 22sec 250ms - Athlon 64 X2 BE-2400@3358mhz - no description
2. rdrash - 12min 47sec 450ms - Athlon 64 6400+ X2@3583mhz - Athlon 64 6400+ X2@3584mhz
3. dealmaster - 12min 59sec 60ms - Athlon 64 5600+ X2@3198mhz - Athlon X2 5600+ @ 3198MHz
4. MarkF - 14min 38sec 790ms - Athlon 64 4600+ X2 Manchester@2820mhz - X2 4600+ Manchester @ 2820 MHz
5. Fangs404 - 16min 36sec 990ms - Athlon 64 4400+ X2 Toledo@2750mhz - X2 4400+ @ 2.75ghz
6. jiggamanjb - 16min 50sec 660ms - Athlon 64 4000+ X2 Brisbane@2727mhz - no description
- 1. tiborrr (OC-Lab) - 1703.83 - tiborrr - 28m 23.828s - AXP 1700+@3149MHz, 2.0V | 2x256MB BH-5 DDR-400@420 2-2-2-7 | Abit NF7-S rev2.0 | 2-stage cascade cooled CPU | Special thanks goes to Moonman for lending OCZ DDR booster!
2. Turrican (Team OCX) - 1849.80 - Abit NF7-S Rev. 2.0, 2x 256MB Mushkin PC3500 Level II "BH-5", 2-Stage Cascade .
3. ThoRax (HW GURUS) - 1876.47 - no description
1. ZL1 - 35min 47sec 170ms - Athlon XP 2800+@2382mhz - XP 2800 @ 2382MHz - Biostar M7NCD
2. Deanzo - 38min 59sec 740ms - Athlon XP 2600+ Thoroughbred@2236mhz - no description
3. jiggamanjb - 54min 8sec 360ms - Athlon XP 2100+ Thoroughbred @1833mhz -
- 1. Asgate (Team Estonia) - 385.87 - no description
2. westyle (JMax-Hardware) - 386.08 - no description
3. TASOS (H.O.T. (Hellas O/C Team)) - 388.66 - no description
1. toddm27 - 7min 5sec 400ms - Core 2 E8500 (3.17Ghz)@5750mhz - [email protected] 605x9.5
2. Brolloks - 8min 46sec 520ms - Core 2 E8600 (3.33Ghz)@4804mhz -
3. ZL1 - 8min 46sec 920ms - Core 2 E8600 (3.33Ghz)@4700mhz - E8600ES E0 @ 4700 w TR120EE + 100CFM - Asus P5K-E
4. TristanW - 9min 3sec 130ms - Core 2 E8400 (3.0Ghz)@4530mhz - no description
5. JLK03F150 - 9min 17sec 690ms - Core 2 E8600 (3.33Ghz)@4400mhz - E8600 @ 4400
6. MarkF - 9min 23sec 880ms - Core 2 E8400 (3.0Ghz)@4275mhz - MarkF -OCFORUMS-: E8400 @ 4275 MHz
- 1. Aristidis (H.O.T. (Hellas O/C Team)) - 209.78 - no description
2. No_Name (AwardFabrik) - 216.48 - deleted on 26/08/2008 17:12:29 by No_Name (owner:No_Name) - AwardFabrik_No_Name powered by Mushkin!, QX9650@5680MHz LN2Pott@ Otterauge, ASUS P5E3WS vMod, Mushkin PC16000@6-5-5-15, Mushkin PSU 800Watt Singlerail!, Please visit www.awardfabrik.de = Overclo
3. mickeymouse (H.O.T. (Hellas O/C Team)) - 216.89 - no description
1. Deanzo - 3min 44sec 890ms - Core 2 QX9650 (3.00Ghz)@5472mhz - 5472
2. Maxi - 3min 53sec 600ms - Core 2 QX9650 (3.00Ghz)@5238mhz - no description
3. toddm27 - 3min 57sec 250ms - Core 2 QX9650 (3.00Ghz)@5600mhz - [email protected]
4. sno.lcn - 4min 32sec 270ms - Core 2 QX9650 (3.00Ghz)@5040mhz - no description
5. glock19owner - 4min 39sec 330ms - Core 2 QX9650 (3.00Ghz)@4465mhz - QX9650/4465/Air Cooled
6. mgoode - 4min 50sec 700ms - Core 2 QX9650 (3.00Ghz)@4227mhz -
- 1. Trouffman (Union Francophone Hwbot) - 482.10 - Testing - Q9100 - GX720 MSI - CPU 8.5*308
2. Barron_Greenback (Bench Tec UK) - 588.28 - no description
3. SiD (OCClub) - 751.01 - MSI GX720, not have modify
1. MarkF - 16min 59sec 270ms - Core 2 T9300 (2.5Ghz)@2492mhz -
2. toddm27 - 21min 39sec 620ms - Core 2 T7400 (2.16Ghz)@2163mhz - t7400 core 2 duo 2.16
3. jmorgan - 24min 17sec 840ms - Core 2 T5600 (1.83Ghz)@1832mhz - ocforums.com
4. sno.lcn - 29min 19sec 60ms - Core T2300 (1.66Ghz)@1663mhz -
5. Dawgdoc - 29min 23sec 780ms - Core 2 T5250 (1.5Ghz)@1496mhz - no description
6. Lemonade727 - 1h 1min 19sec 700ms - Core T2310 (1.46Ghz)@1463mhz - no description
- 1. leghorn-giorgioprimo (MemoryExtreme Italy Team) - 110.13 - no description
2. k|ngp|n (KINGPINCOOLING.COM) - 112.25 - SKULLTRAIL QX9775 Dragon F1 eXtreme LN2 cooled | overclocKingpin.com
3. pro (i4memory.com) - 121.16 - dual kayl pots on skulltrail @ 5.3ghz on dice, 1.8v, fbdimm, intel d5400xs, 9775, this platform is very seckzi =]
1. ZL1 - 4min 27sec 810ms - Core 2 Q9550 (2.83Ghz)@4604mhz - Q9550 E0 @ 4604 w TR120EE + 100CFM - EP45-UD3P
2. ghost_recon88 - 4min 32sec 220ms - Core 2 Q9550 (2.83Ghz)@4522mhz -
3. Brolloks - 4min 33sec 890ms - Core 2 Q9650 (3Ghz)@4454mhz -
4. Dawgdoc - 4min 43sec 790ms - Core 2 Q6600 (2.4Ghz)@4640mhz - no description
5. automiketic - 4min 48sec 110ms - Core 2 Q9400 (2.66Ghz)@4208.20mhz -
6. toddm27 - 4min 58sec 60ms - Core 2 Q6600 (2.4Ghz)@4544mhz - q6600@4545
- 1. MusicIsMyLife (benchbrothers.de) - 143.85 -
2. Aristidis (H.O.T. (Hellas O/C Team)) - 144.22 - no description
3. Sergey13 (Russian Overs-Overclockers.ru) - 146.67 - no description
1. mgoode - 2min 43sec 120ms - Core i7 960@4750mhz - core i7 960 on h20
2. Ross - 2min 48sec 80ms - Core i7 920@4493mhz - Core i7 920 @ 4493MHz
3. Deanzo - 2min 49sec 90ms - Core i7 940@4388mhz - no description
4. rdrash - 3min 0sec 560ms - Core i7 920@4254mhz -
5. Brolloks - 3min 4sec 830ms - Core i7 940@4200mhz - 940
6. Woomack - 3min 5sec 440ms - Core i7 920@4163mhz - no description
- 1. tiborrr (OC-Lab) - 1967.22 - tiborrr - 32m 47.219s - Duron 1600@2728MHz, 2.0V | 2x256MB BH-5 DDR-400@455 2-2-2-7 | Abit NF7-S rev2.0 | 2-stage cascade cooled CPU | Special thanks goes to Moonman for lending OCZ DDR booster!
2. maX (HW GURUS) - 2024.02 - Duron 1800MHz Applebred, Abit NF7 v2.0 w/tictac's Black Mantaray XT D26 CPC on bios, 2x512MB Corsair CMX-3200C2 v4.2 TCCD CAS2-2-2-4, water cooling from Kandalf LCS
3. Jn_Freeman - 2093.20 - no description
1. ZL1 - 1h 11min 26sec 160ms - Duron 850Mhz@1192mhz - Duron 850 @ 1192MHz - Biostar M7NCD
2. jiggamanjb - 1h 18min 1sec 640ms - Duron 1.2ghz@1200mhz -
3. Deanzo - 2h 12min 46sec 560ms - Duron 700Mhz - AMD Duron 700Mhz
- 1. Pheelon (HardwareLuxx Germany) - 115.99 - no description
2. Krohpit (Russian Overs-Overclockers.ru) - 128.80 - Tyan 4*Opteron8356
3. ALT-F13 (Team MXS ModLabs.net) - 131.08 -
1. The Wicker Man - 13min 35sec 950ms - Opteron 165 .09@3006mhz -
2. jrafael - 15min 51sec 480ms - Opteron 170 .09@2860mhz -
3. Big Mike - 16min 9sec 500ms - Opteron 165 .09@3060mhz - Opteron 165 @ 3060
4. rpkole - 16min 27sec 940ms - Opteron 165 .09@2700mhz - 2.7 opty
5. Dan0512 - 17min 36sec 140ms - Opteron 170 .09@2800mhz - AMD Opteron 170 @ 2800Mhz
6. ZL1 - 31min 29sec 830ms - Opteron 146 .09@2906mhz - Opty 146 @ 2900MHz w stock sink - OEM Giga K8N Ultra
- 1. MaSell (Team OCX) - 1365.13 - no description
2. F.O.G.N.A. (PcTuner.net OC Team) - 1493.50 - no description
3. Nordling (OCClub) - 1676.74 - no description
1. eaglescouter - 33min 53sec 160ms - Celeron LGA775 360@5902mhz - Celeron 360 @ 5.902Ghz on Single Stage Phase Cooling
2. ZL1 - 47min 20sec 700ms - Celeron s478 2.4Ghz@3608mhz - Celly 2.4 C1 @ 3608MHz w TR SP94 - Abit AI7
3. sno.lcn - 47min 42sec 200ms - Celeron LGA775 331@4029mhz - Celeron 331 @ 4029mhz
4. Woomack - 54min 36sec 250ms - Celeron s478 325@3610mhz - no description
5. Deanzo - 1h 3min 39sec 500ms - Celeron s478 2.8Ghz@2788mhz -
- 1. demiurg (Team MXS ModLabs.net) - 921.79 - no description
2. Maduk (pc-overware.be) - 929.91 - no description
3. jabski (Bench Tec UK) - 945.22 - no description
1. ZL1 - 20min 28sec 280ms - Pentium 4 'D' 940@4408mhz - D940 B1 @ 4400MHz w Zalman9700 - Asus P5K-E
2. sno.lcn - 21min 50sec 0ms - Pentium 4 'D' 930@4003mhz -
3. Deanzo - 22min 44sec 660ms - Pentium 4 'D' 920@4114mhz -
4. batboy - 40min 41sec 560ms - Pentium 4 'D' 940@4213mhz - Intel Pentium D 940 @ 4.2Ghz
- 1. George_o/c (H.O.T. (Hellas O/C Team)) - 1859.03 - TOO much voltage on my mushkin rams - approaching their limit ! Kind of "loose" sub-timings ... Room temperature = 18*C
2. BootSector (Russian Overs-Overclockers.ru) - 1866.63 - no description
3. leeghoofd (Madshrimps Belgium OC Team) - 1875.75 - no description
1. ZL1 - 35min 6sec 410ms - Pentium 4 3.0Ghz Prescott@4206mhz - P4 3.0E G1 @ 4206MHz w TR SP94 - Abit AI7
2. Dawgdoc - 35min 11sec 140ms - Pentium 4 3.2Ghz [email protected] - no description
3. batboy - 40min 57sec 80ms - Pentium 4 2.4Ghz C Northwood (HT)@3300mhz - P-4 2.4C M0 @ 3.3Ghz
4. The Wicker Man - 52min 11sec 60ms - Pentium 4 2.8Ghz C Northwood (HT)@3082mhz -
5. Khemikal796 - 1h 4min 57sec 80ms - Pentium 4 2.4Ghz C Northwood (HT)@2405mhz - no description
6. Woomack - 1h 13min 20sec 220ms - Pentium 4 1.6Ghz@2424mhz - no description
- 1. ZL1 (OC Forums) - 943.22 - D955EE B1 @ 4733MHz w TR120EE + 100CFM - Asus P5K-E
2. ALT-F13 (Team MXS ModLabs.net) - 943.86 - no description
3. jabski (Bench Tec UK) - 973.94 - no description
1. ZL1 - 15min 43sec 220ms - Pentium 4 955 EE@4733mhz - D955EE B1 @ 4733MHz w TR120EE + 100CFM - Asus P5K-E
2. toddm27 - 29min 57sec 640ms - Pentium 4 524@5427mhz - pentium 4 524@5427
3. MarkF - 38min 12sec 560ms - Pentium 4 640@4320mhz - Pentium 4 640 @ 4320 MHz
4. Woomack - 43min 48sec 500ms - Pentium 4 650@3852mhz - no description
5. batboy - 48min 35sec 470ms - Pentium 4 506@3603mhz - Intel 506 @ 3.6Ghz
6. Khemikal796 - 54min 43sec 640ms - Pentium 4 550@3391mhz - no description
- 1. masterchorch (benchbrothers.de) - 1820.78 - no description
2. loopy83 - 1831.53 - no description
3. Duronbird (OC-Papat) - 1847.50 -
1. Woomack - 45min 15sec 280ms - Pentium M 745@2100mhz -
2. Italidonian - 47min 35sec 890ms - Pentium M 725A@2128mhz - Italidonian -OCForums-
3. sno.lcn - 1h 6min 12sec 760ms - Pentium M 1.5Ghz@1500mhz -
4. toddm27 - 1h 6min 22sec 960ms - Pentium M 1.4Ghz@599mhz - pentium m 1.4
5. MarkF - 1h 7min 52sec 880ms - Pentium M 753@1476mhz - Pentium M 753 @ 1477 MHz
- 1. FoX [Hard-Concept.Net] (Team OCX) - 139.97 - FoX @ Alcarras Lan Party 2009!
2. AndreYang (KINGPINCOOLING.COM) - 140.84 -
3. Brian y. (KINGPINCOOLING.COM) - 142.39 - no description
1. pauld5999 - 2min 32sec 250ms - Xeon [email protected] - no description
2. mgoode - 2min 50sec 750ms - Xeon W3520@4188mhz - xeon w3520 @ 4.5ghz on h20
3. Woomack - 4min 42sec 700ms - Xeon X3360@4307mhz - no description
4. sno.lcn - 5min 51sec 720ms - Xeon 3210@4105mhz - Xeon 3210 @ 4105mhz
5. RangerXLT8 - 6min 24sec 710ms - Xeon [email protected] -
6. Dawgdoc - 6min 25sec 630ms - Xeon 3220@3942mhz - no description
