Temps are what I would expect for a stock cooler, core temps in the mid 50s that is. Cooler is doing its job but please take note that if you want to overclock this CPU you will definitely need a good aftermarket cooler.
I'm more concerned with the minimum CPU voltage (CPU vcore) I see in HWMonitor. It's 1.28. Did you notice that reading came under load or at idle? If you are not sure do a short Prime95 run to check that out. If that low vcore is under load then it may not be enough to keep the CPU stable under a heavy load like gaming.
Memory Overvoltage
For Memory Overvoltage it says
"min = 1.5000 V
max = 2.3100 V
Standard = 1.5000 V
Increment = 0.0150V
+/-: Raise / Reduce"
Don't hang me for taking a guess here, but could the "max = 2.3100v" the culprit here?
Memory Overvoltage
"min = 1.5000 V
max = 2.3100 V
Standard = 1.5000 V
Increment = 0.0150V
Look for what the CPU vcore shows in HWMonitor after the the CPU is pulling a full load. It may go up, it may go down depending on how your bios is configured to respond to load.
Here's what I'd like you to do:
1. Give the CPU vcore a slight bump in bios voltage. Whatever its set to now, give it the smallest increment higher, like .015 more or something like that. Your temps won't take much more voltage but a tad more may be okay for everything but Prime95.
2. Give the CPUNB a bump to 1.225 volts.
3. Give the memory a voltage bump to 1.55.
See if that helps the random instability problem.
Ultimately, I would suggest you get a good aftermarket CPU cooler.
