You'd have to put pins and a connector on it. You can get tools to do it yourself.
I just use a pair of needlenose pliers to bend the tabs over, then solder them to the wires myself. Makes for a nice, secure connection. Plus that way I don't have to buy a crimper.
I don't quite understand how you can crimp something wrong. If you do it wrong, the pin just doesn't stay on the wire, so the length shouldn't matter. >.>make sure you learn how to crimp before attempting this, if you've never crimped anything before it can be a bit tricky, and unlike many other things you crimp, the fan cables are rather limited in length.
It is extremely easy once you get it down. It has been a long time since I did my first one, but I don't remember it being difficult.
Oy, don't remind me. I ran Ultra High Speed Panaflo fans (Thick/powerful 38mm fans) on my radiators, when I did water cooling. I ran 5 of them (3 on the back side, 2 on the side facing the case) and didn't think I needed to have fan guards on the ones facing the case. Since they were pushing through the radiator (away from the system), they were completely open and very sharp. I was working on the system (don't remember what I was doing) and my finger slipped into the fan. Cut it right down to the bone. That was lovely. Got to paint my case that day. Although, the red didn't look good on black.Do yourself a favor and buy a fan guard for the intake.
High speed high power fans will take the end of your finger off if you let 'em.
delta is model no. ffb0912sh
