- Jan 17, 2004
- Pyeongtaek, South Korea
I'm trying to find the best way to stick two fans together back to back without using screws. Basically, I want to use some kind of soft adhesive material (about 1/8" or 1/16" thick) or use a soft non-adhesive material and add apply the adhesive. The goal here is for the "gasket" to be soft (in order to absorb vibrations from the fans) while still having a strong enough bond to last a decent length of time (at least a year or so).
Any ideas? I thought of using foam rubber and super glue, but I want to be able to remove it in the future. Is there some kind of maleable sealant that I can use? Should I wrap double-sided tape around neoprene rubber? All suggestions welcome!
