Here's a mini Gigabyte GTX 1060 3GB card that has what you need.
The card looks exactly what I'm looking for however the reviews on the gigabyte card that you gave me the link to are not that good. So I'll continue to search but thanks for your reply
OK just get one of these HDMI to DVI Adapters with any GTX 1060 since they pretty much all have 2 HDMI ports and 1 DVI port.
A. Dap. Ters......
I'd rather stay with what I have now so looking for a card with 2 DVI and 1 HDMI
I just looked at the reviews.. yes there are some low ratings there but the overall 4 eggs is actually decent, I personally would absolutely go ahead since it has the features you require.
Almost all the products I have bought through newegg have had 1 egg and 2 egg ratings with DOA and various reports, but its quite normal that for the small percentage of people who experience issues to ensure they leave a low rating comment.
It will work in any pciE slot. Probably best performance in fastest slot(too one?)
Usually bottom one is x4 and two top ones are 16x. You probably will never notice any difference unless you game hard and card is saturating 4x sloth
No card will/should touch the memory. A back plate is all that is on there.
Putting an image on the screen take nothing. A 4x slot wound be fine.
I swear we are putting a man on the moon here.
There is t a need to apologize. I was trying to make sure that the decision making process wasn't getting lost in the minutia is all.
GL with your purchase... let us know how it works!!
