- Jul 6, 2016
I've read that ultimately, OCing your CPU is safe until you start playing with voltage, and as a result, higher temperatures. If, for example, I kept increasing the voltage so that I could increase my clock speeds/multipliers, as long as my temperatures stay in a safe range, is there any harm to this? Is there a point where you can have too much voltage, but still be at a safe temperature? Or is temperature what really matters, and increasing voltage is fine until it starts getting too hot?
For a while, it was impossible for me to get my CPU hotter than 55°C. Then I started using an additional stress test (Prime95), and it got my CPU working, with the hottest core being 69°C. I know this is still safe, but while it's being stressed, the Vcore goes as high as 1.404v, with an average just under 1.4v. Temperature wise, I know I am okay, but from what I've read about voltages, 1.4 is pretty high...too high, in some peoples' opinions.
Just so there is no confusion, I wanted to make it clear that I don't really know what I'm doing. The only reason I've been successful thus far is because the BIOS settings are basically all set to auto. All I have to do is indicate the multiplier I want to apply, and it sets all the different voltages accordingly. It would appear to work just fine that way. The voltage is adaptive, by the way.
I guess the other main question I have is, is it worth it? Would trying to push this CPU to 4.6 or 4.7 be worth it? I've tried before and have always failed, although I now know what I believe the problem was (voltage would not auto scale high enough, so I was setting it manually..way lower than necessary). I guess the answer to this question depends on the answer to the first question. This rig is my baby, and I don't want to hurt it or cause any harm. I just spent 2 grand on it and I can't imagine damaging components.
Relevant system specs:
Intel i5-6600k 3.5GHz
Gigabyte Z170MX Gaming-5
MSI GeForce GTX 980 4G
16GB DDR4 2133 Dual channel RAM
Thanks everyone for your support
