- Jan 12, 2012
If one leaves the voltage on auto, the board will do it's best to provide the chip with the voltage it needs for X mhz. When overclocked the board will compensate to a point. If the voltage in your Cpu-Z Valic SS is accurate 1.43 v is not stock Vid (for joe) . I imagine you may get a bit better Oc if you manually set it. That voltage for the corresponding Mhz seems a bit high from what I've seen.
