hello again red good to see you again.
ok did what you said dropped the IOH Vcore to 1.10 from 1.400
dropped the ICH Vcore to 1.05 from 1.250
and temps are going down as we speak
idle temp Vreg was 66c after 45 min
Idle temp Vreg is 57-58c after 2-3 min so far
Vcore is set to 1.32v atm idle temp CPU is 30-31c
so where should my Vreg be at to start my Stress test
Can you tell me the utility you used to check VRM temps please??
Do you still not get where I meant with the fan? I can make a drawing.
its a good tool for benching with evga boards (aside from that little ipod looking gizmo) Real time boosting blck and voltages.. I played with it one day on my pc and @ 1.34v I got my system up to 4.6GHz.. for a few seconds.. don't think I woulda gotten a capture if i wanted to!
I'd have to look into it.. I'm not part of the benching team, just wanted to see what I could do w/o breakin stuff
let me try a lower Vcore ill do the 1.27 firstyou could try dropping vcore down.. if its D0 you should be able to get a 4GHz oc at 1.27-1.29 if not lower.. i gave you wider spectrum of settings to get you started.
And no problem.. that's what we're all here for.
Ok so i looked at my bios and this is my small template:
Without Vdroop
CPU Vcore to 1.27
CPU VTT +200
CPU PLL Auto
QPI PLL Auto
DIMM Voltage - 1.65V
DIMM DQ Vref - +0mV
QPI PLL VCore - Auto
IOH VCore - 1.375V
IOH/ICH I/O Voltage 1.575V
ICH VCore - Auto
PWM Frequency - 800 KHz
