My 920 bloomfield 2.66 on GA-X58A-UD3R @ 4.03Ghz.
GIGABYTE GA-X58A
MB Intelligent Tweaker(M.I.T.)
> Advanced Frequency Settings [Press Enter]
CPU Clock Ratio............................:21
CPU Frequency ........................(GHz):4.03GHZ 192x21
> Advanced CPU Core Features [Press Enter]
Intel(R) Turbo Boost Tech..................
isabled
SHOULD THIS BE DISABLED?
CPU Cores Enabled..........................: ALL
CPU Multi Threading........................: ENABLED
CPU Enhanced Halt (C1E)....................
isabled
C3/C6/C7 State Support.....................
isabled
CPU Thermal Monitor........................:Auto
CPU EIST Function..........................
isabled
Bi-Directional PROCHOT.....................:Enabled
QPI Clock Ratio............................: X36
QPI Link Speed........................(GHz): 6.91GHZ
Uncore Clock Ratio.........................:X13
Uncore Frequency......................(MHz): 2496Mhz
>>>>> Standard Clock Control
Base Clock(BCLK) Control...................:Enabled
BCLK Frequency(MHz)........................:192
Extreme Memory Profile(X.M.P.).............
isabled
System Memory Multiplier (SPD).............:6
SHOULD THIS BE 8?
Memory Frequency(MHz)......................:1066 1152
PCI Express Frequency(MHz).................Auto:
>>>>> Advanced Clock Control
CPU Clock Drive (mV).......................:800mV
PCI Express Clock Drive (mV)...............:900mV
CPU Clock Skew (ps)........................:0
IOH Clock Skew (ps)........................:0
> Advanced Memory Settings [Press Enter]
isabled
SHOULD THIS BE 8?
Memory Frequency(MHz)......................:1066. 1152
Performance Enhance........................:Standard
SHOULD I HAVE THIS SET FOR TURBO OR EXTREME?!
DRAM Timing Selectable (SPD)...............:Quick
Should this be AUTO
Profile DDR Voltage........................:1.5V
Profile QPI Voltage........................:1.175V
Channel Interleaving.......................: 6 AUTO
Rank Interleaving..........................: 4 AUTO
>>>>> Channel A, B, & C
> Channel A, B, & C Timing Settings [Press Enter]
>>>>> Channel A, B, & C Standard Timing Control
Cas Latency Time...........................:7 AUTO
tRCD.......................................:7 AUTO
tRP........................................:7 AUTO
tRAS.......................................:20 AUTO
>>>>> Channel A, B, & C Advanced Timing Control
tRC........................................: 27 AUTO
tRRD ......................................:4 AUTO
tWTR ......................................:4 AUTO
tWR........................................:8 AUTO
tWTP.......................................:19 AUTO
tWL........................................:7 AUTO
tRFC.......................................:60 AUTO
tRTP.......................................:4 AUTO
tFAW.......................................:16 AUTO
Command Rate (CMD) ........................:1 AUTO
>>>>> Channel A, B, & C Misc Timing Control
B2B CAS Delay..............................: - AUTO
Round Trip Latency.........................:58 AUTO
> Channel A, B, & C Turnaround Setting [Press Enter]
>>>>> Channel A, B, & C Reads Followed By Reads
Different DIMMs............................:6 AUTO
Different Ranks............................:5 AUTO
On The Same Rank...........................:1 AUTO
>>>>> Channel A, B, & C Writes Followed By Writes
Different Ranks............................:6 AUTO
> Advanced Voltage Settings [Press Enter]
>>> CPU
LoadLine Calibration.......................: AUTO
CPU Vcore..................................:1.31250V
xDynamic Vcore(DVID).......................: 0.0 AUTO
QPI/VTT Voltage............................:1.335V
CPU PLL....................................:1.8V
>>> MCH/ICH
PCIE.......................................:AUTO
QPI PLL....................................:1.200V
IOH Core...................................:AUTO
ICH I/O....................................:AUTO
ICH Core...................................:1.2V
>>> Dram
DRAM Voltage...............................:1.5V
DRAM Termination...........................:AUTO
Ch-A Data VRef.............................:AUTO
Ch-B Data VRef.............................:AUTO
Ch-C Data VRef.............................:AUTO
Ch-A Address VRef..........................:AUTO
Ch-B Address VRef..........................:AUTO
Ch-C Address VRef..........................:AUTO
> Miscellaneous Settings [Press Enter]
Isochronous Support........................: Enabled
Virtualization Technology..................: Enabled
