I recently installed new memory modules and they work great but when I tried to turn on XMP in the bios, it caused my pc to have a boot failure and it reset the cmos. before this my processor was overclocked to 3.82 ghz with my old memory but after installing the new memory, the most i can get out of the pc without it crashing is about 3.2 ghz (160 BCLK x 20). I think that it may be that I must increase the voltage in order to increase the speed but I am a near complete rookie at this (my previous OC was done by the company I ordered the parts from). I have tried using the BIOS but that resulted in almost total failure so I have been trying with the gigabyte easy tune 6 utility and that was where I managed to get to 3.2 ghz up from the stock 2.66 ghz. I can also only manage to get my memory running around 1280 mhz instead of the 1600 it is advertised as in addition to me having different latency settings that advertised. I have included some pictures of my cpu-z results and my current settings on easy tune 6. If anyone could tell me what I am doing wrong or which settings I should be attempting to change to get a higher and more stable overlock I would be very grateful. ALso as i said, please bear in mind that I am pretty damn new to overclocking and while I am generally pretty pc literate compared to the average (not that that is necessarily something overly impressive) and a relatively quick learner, my knowledge of this topic is limited.
(album with a bunch of my settings and results)
I have added some pictures of my bios too so people can see what settings I have to work with.
I should point out that stability is not the issue in that whenever i restart from the bios, i simply get a black screen and the pc will not boot although it does not switch off.
