- Thread Starter
- #141
Torin,
Wow ! Just knew it if that mobo can go as low as 0.4 Volt ! Although I'm sure at that level it will be usable with current CPU generation.
For UVOC test, the VCore should be manually set and don't use Auto.
Just use the VCore setting (not the reading) from the bios, and again not from the CPUZ.
Fyi, nowdays the vcore set by the bios is quite accurate, especially for recent highend OC-ing mobo starting from P965 generation.
Yes, you're right, CPUZ vcore reading is a hit and miss situations at different mobo models and different Super IO chips, and until there is a unified method and initiative from Super IO chip maker and/or Intel, Franckz (CPUZ author) will never able to put the VCore value in the CPUZ validation.
Just do the UVOC method as I mentioned at the 1st post, and I'm really curious for your temp delta of yours since you're on highend water.
Thanks for the offer, dunno if its useful, you could try UVUC (Under Voltage Under Clocking) .. LOL ..sounds funny.
It's the way to find the "lowest" cpu speed by lowering the multi or/and fsb with the "lowest" VCore as possible.
Can't imagine the temperature delta at UVUC, must be really-really low !
Regarding your upcoming UVOC result, just put it on a new post instead of editing the old post.
