So it's stable at stock speeds with the GTX 760 installed? If so, that does not point to the video card as the problem.
What about flashing the bios to the latest version? I don't think anyone has mentioned trying that yet. The current bios version could be buggy or corrupt.
I have the same problem, but with completely new build.
My current setup:
Gtx 1080ti rog strix
I5 8600k
ASRock z370 pro4
G.skill Ripjaws 3200 c16
Psu chieftec 850w
So, my problem is nearly the same. First of all I OCed my i5 to 5.0ghz with 1.39v and that's stable for me (tested with prime95 no avx for 1h and <85°). But, when I try to run any GPU benchmark it becomes unstable and my PC just turns off in 3DMark or userbenchmark gpu test (and every time in the same moment). Never bsod. Just turns off and reboot.
Then I tried to run that tests with stock CPU core and see whats going on. And it crashed again. Then tried xmp off and it passed! A few times in a row... I can only use my rig in a stock?
Then i tried to make some tests with my old gtx 760 and it runs perfect any stress situation with CPU 5.0ghz and xmp on. I checked MSI afterburner graphics to see that exactly moment when my PC turns off and that was peak of GPU FB usage. So it looks like that peak of gpu frames buffer usage causes instability in my system. And that is GPU issue, right?
In Tuesday I'll try my luck with another PSU 1,2kw. I still hope that this is not GPU issue.. how can i proceed RMA with GPU if it just works fine with stock system
PS I used DDU, even more I completely reinstall my OC. Didn't use any settings in bios, all default from the box.
If your saying you only have a problem running XMP then the problem is the memory not the PSU. Try one stick of memory at a time running XMP to see if you have one stick unable to run XMP speed stable. If running the sticks separately with XMP and the PC is not stable then you will have to try lowering the memory speed or increase memory timings for stability.
If everything works fine with default setting, then the overclocking is the problem. Overclock one thing at a time and test for stability.
